I think you should try FilmoraGo app it is totally free and you can get it from here
Is the "Stripe line" appearing when you use an arftificial (LED or Fluorescent) light source?
They flicker and can cause a line or interference pattern on the camera.
SOURCE: My Samsung SL30 Camera, are
The battery requires recharging else a new battery is required to replace a depleted once. Perform a power recharge of the device for several hours to attain full capacity. The camera lense should responde there after.
Is this stripe or line only in the viewfinder, or does it appear on the images as well ? If only in the viewfinder, then you may have to just ignore it, as a repair would be expensive.
It appear on the image sir.
What color is the stripe? Is it exactly straight?
