Nabi 2 Logo
C
Crystal lester Posted on Apr 07, 2016
Is there a way to still charge a nabi 2 without using the little round charging port?
The little peg is broke off inside. Is there any other way to charge?
1 Related Answer
makgss
  • 29 Answers
  • Posted on Jan 08, 2015
SOURCE: We lost the charger for a few weeks when we found it now the nabi won't charge.
The charging cables are also quite finicky. If you are getting red/green flashing LED on the Nabi, be sure to turn it all the way off before charging. Also, wiggling the cable can get the unit to hold a red (charging) LED state - give it 10-15 seconds to determine if it is getting enough current to charge and the LED to settle.
My nabi wont turn on
Here are trouble shooting tips from the Nabi site:
https://www.nabitablet.com/support2/fb/top-10-faqs/nabi2/2
Also, there appears to be a problem with the wall charger so it's better to charge it via USB to computer instead of from the wall outlet. That might be the reason why your Nabi won't turn on.
Here's more information regarding the charging problem:
https://www.facebook.com/nabitablet/posts/301200709922574
Oct 06, 2015 • Nabi 2
How do i charge my nabi2 if my charger hole is broken
If it truly is the connector in the Nabi, you're in a bit of a jam. But, the power cords I find are very finicky. I have two Nabi's and each has its "preferred" charging cable. One cable works better than the other on each tablet. Before attempting any major repair, try another USB charging cable. You can get the cable for under $4 on Ebay. Make sure you have a high powered USB source (2 Amp or 2000 milliamp) or it won't provide enough juice to charge the tablet. Beyond that, I also sometimes have to "position" the cable just right, twisting the connector and cable till I get the red charge light to stay on. Often this requires I fully power off the Nabi, not just put it into stand-by. Good luck.
Feb 26, 2015 • Nabi 2
2answers
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 • Nabi 2
I have a Nabi that all of the sudden even if the green light is on saying its charged the screen stays black
Sounds like you have a good charger/cable, so try resetting the Nabi that's giving you trouble. Hold the power switch down for 10-20 seconds to reset the unit.
I have a couple of NABI-2 tablets and they both react differently to the charging cables; I often have to shut the NABI off completely to charge them. Also, getting the charging cable to connect can be challenging - I will plug the cable in and out several times waiting 10 seconds or so to see if the green LED will go red.
Dec 31, 2014 • Nabi 2
1helpful
Charger
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
Apr 16, 2014 • Nabi 2
2answers
My nabi tablet is charged but wont turn on
Try a different charger first, as it maybe faulty. If not the battery maybe faulty and I would purchase a new one.
Mar 16, 2014 • Nabi 2
1helpful
3answers
My charge got broke can i use a regular usb charger
Press "Volume +" together with "Power on", during 8-10 seconds. Choose first line in menu.
Nabi 2 freezes when charging
I fit is a new tablet, I would take it (/send it ) back to supplier and complain and/or ask for a replacement.
If it is not new, then... hmmm.
Jan 11, 2014 • Nabi 2
2answers
Nabi will not charge .have new charger
Whenever you plug in your Nabi 2 tablet to charge, The tablet will boot up. Whenever tablet boots up, turn it off and leave it charging for a good 4 to 6 hours. That should charge it.
Aug 12, 2013 • Nabi 2
Top Nabi Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
techy
Level 1 Expert
Ari Garcia
Ari Garcia
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
