How do I activate the bypass auto start on Toshiba 2540c. Currently it suspends every job and I have to manually hit start.
Currently when I send a job to print on my Toshiba 2540C to the bypass feed I have to manually go to the copier and select the job then hit start. Every job that goes to the bypass automatically suspends. I read that this is the way the toshiba function but I also read that you can put a code at 08 that will allow you to make the bypass to auto start. However I tried all codes I found and none work. Can anyone let me know the code or a way to do this?
Update: From a previous post I found online I did 08/658 but that did not work.
You can put special media on side bypass feed tray. Then select paper type/thickness. Choose the bypass tray and paper type when sending print job from your PC. Job status light will blink and you need to go to the copier to execute the print job for special paper.
error C 449 Heater lamp abnormality after abnormality judgment (temperature abnormality at high temperature)
first of all just reset error with simulation may just malfunction error procedure for rest error for heater related.
turn copier off
hold down 0 & 8 while turning it on power switch
then press digit numbers 4 0 0 then press start key
then 0 key and set
try to format its HDD : turn it off.. hold 0
and 8 while turning on the copier, when the machine comes ready key in
690 and hit start. It will then display "2 2", hit start again or enter .
Wait for it to say "please reboot the machine", turn it off and back on.
Hopefully this will work..
If your account has been suspended then you are wasting your time for become your account active. Just sign up a new account. Because those account are suspended by Facebook never became active.
