Good water flow at waterline Connection, but very slow weak at dispenser
Hello Chuck, thank you for your post!
From the information you have provided you are receiving low water pressure at the dispenser on your Frigidaire refrigerator. This could be due to a dirty or clogged filter and I would check to see when you last replaced it. I have researched model FRS3R5EMB and show the water filter is part number WFCB.
If you have changed your filter within the past six or nine months the low pressure could be due to an obstruction within the water line or an issue within the dispenser. Since it could be anyone of these underlying issues I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. I hope that this information is helpful to you. -Matt
SOURCE: slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
SOURCE: my water filter is only 2 months old but the water
In can be partially stopped up at the water inlet valve on the back where the water supply comes in from the house. There is a mesh screen in the valve where the supply hooks up. When you have it disconnected let it run into a pail to flush out any sediment in the supply line.
SOURCE: I've just replaced the water filter and the flow
Hi and welcome to FixYa, I am Kelly. Most water flow problems that are common to both the ice maker and water dispenser are either a supply volume or filter problem. Since you already have replaced the filter that points directly to a supply volume problem. Water connections for refrigerators are often connected by using a saddle valve on the side of a water pipe. The saddle valves have a rubber gasket that is clamped to the side of the pipe to prevent leakage. The gasket over time can swell due to being clamped or plumbing debris can block the small hole that ports water to the refrigerator water supply.
Here is what I recommend. Disconnect the water line where it connects to the back of your unit. If you have the press in type connection (no visible fittings) at the water inlet valve I recommend you get a brass compression coupling and cut the plastic line vs pulling the plastic line out of the water valve. Install the coupling on the plastic line so you will have a connection to check the flow rate.
The incoming flow rate should be the same as the water dispenser flow rate. If the incoming flow rate is faster then the problem is with the refrigerator internal plastic tubing. Most of the time when this discrepancy appears it will be in the door hinge area that the tubing is flattened causing a restriction in water flow. Since you are having both ice maker and water dispenser problems... your problem most likely is strictly water supply line related. Correct the water supply problem.
Thanks for choosing FixYa,
Kelly
SOURCE: Slow water flow from water
Hi.
Either low pressure from the line, or blockage in fridge water hoses going to the dispenser.
If water pressure is OK, then the problem is often given by a blockage caused by water freezing in the fridge's hoses. Try doing a complete defrost.
If defrost does not help you will need to find blockage accessing the hoses, start from the inlet at the back of the fridge.
Do defrost first.
Regards.
Ginko
SOURCE: water flow
check the heater in the fridge compartment as it is on a timer to defrost the water line that goes through the rear compartment and allows the water to flow
In some models it creates an automatic by-pass when the filter is removed. If this is one of those models remove the filter and use the dispenser with it out. If you get good pressure now, it indicates a problem in the filter housing. If it's still slow it could be due to low supply water pressure or a defective valve. You can check the water at the valve inlet and outlet. First turn the inlet (main) water supply valve off. Now disconnect the water inlet line at the valve and place the end of it in a pitcher. Turn the water valve back on and check if there is a good solid water flow. If the water flow is good reconnect the water to the valve and now take the water line loose on the back side of the valve. Activate the water dispenser and check how the water flow is coming out of the valve. You will probably need another person to help you with this check. If the water seems slow, then the valve will need to be replaced.
