Want to set the date and time for your mobile phone? Follow these easy instructions. From a Home screen, tap the Arrow icon to display all apps.
Navigate: Settings > Date & time.
To use network-provided values, turn on the following:
Automatic date & time
Automatic time zone
When manually setting data & time, perform the following:
Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
Tap Set date.
Adjust the date then tap OK.
Tap Set time.
Adjust the time then tap OK.
Tap Select time zone then select a time zone.
If desired, tap Use 24-hour format to turn on or off .
The date display option can come from your camera or the software programme you use to view. Start with the software and disable the date & time display function. If this doesn't work then go into the camera menu and in the display setting change the date & time to either disable or none.
Set the date and time: The current date and time are shown in the display when the machine is on and ready for use (Ready mode). The date and time will be printed on all faxes you send. 1. Press Menu. 2. Press Left Right Arrow to choose SET DATE & TIME and press Start/Enter. 3. Press Start/Enter when the display shows Date Format. 4. Press Left Right Arrow to select either Europe (day month year) or USA (month day year) and press Start/Enter. 5. Press Start/Enter when the display shows Date & Time. 6. Set the date and time. You can move the cursor by pressing Left Right Arrow. 7. Press Start/Enter when the date and time are correct. 1-AM 2-PM will display. 8. Press 1 or 2.
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is). with the handset down, enter #20 the screen should say MMC DISABLED 1) enter in 1 2 3 4 1 # (that enables programming) 2) enter in #55 the screen should say YYMMDDWHHMM 3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.) press # when finished.
press the CA button to get your time/day from being displayed. For your date... whenever you press the time button to edit your time, press it again & your date shouold come up. the time/date button are both done with the TIME key.
I have posted a video which shows step-by-step how to change the date and time, written version is available at http://www.abbeytelecom.com I hope that this helps
