Zeki Berk Ulu 8GB 7in WiFi Android Tablet - Black/White Logo
A
Anonymous Posted on Apr 09, 2016
Even though I reset my tablet,it is still missing my settings
I've reset my tablet,but I click on my settings!its there then its not,can u help
My icraig tablet has got a pic of the prior owner and it can't be removed. And to compound that it won't even let me remove it. I have tried every thing, but l'm missing something.
Hi if u do a factory data reset it will delete it DONT FORGET TO BACK UP DATA .click on setting ICON u should find back up & reset .cheers
How do i reset my password on my linda pitts 06@ gmail account
When logging in press forgotten password option and follow instructions!
Sounds and discplay
There is some corruption, I think a factory reset should do the trick.
My LG slate tablet wont turn on
my son charged mine with the car charger for higher voltage charge and its working fine now
1helpful
Key clicks is ON , but NO sound
Is it possible that you also changed the function of the lock switch?
Try going into settings and change the settings of the lock switch to mute/unmute then place the switch itself into the unmute position.
If that brings back the sound of the keys, then it's safe to change the lock settings back to lock rotation.
If that doesn't solve the issue then I would recommend you do a backup and then restore to factory settings using your computer and iTunes.
Hope that helps!
2answers
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
Top Zeki Berk Ulu Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Zeki Berk Ulu Tablet and eReader Expert? Answer questions, earn points and help others
