Question about Shopnbc Zeki 7" Multi-TouchTablet
How to I get my settings back in my tablet
I click on my settings,its there then poof its gone,I don't have it where it says videos,cache,my apps,etc.
How do I move apps, pics, etc to SD card? Internal storage is full
For Android users, get the app Android Assistant and run it, use the Tools tab and choose the tool named "APP2SD" and choose an app from the list. When the app description appears, click on the STORAGE button and then click on CHANGE and click on SD to move the app from "Internal" to "SD card". Wait for the app to finish being moved, then back out to the list of apps that can still be moved to the SD card and do the next app. Be aware that when apps get updated, they will move back to the internal memory, so I usually check with APP2SD about once a week and move things as needed to my SD card. For space on my SD card, I chose a 128GB micro SD card and I've only filled it about 1/4th of the way over the past year. This is the safest way to move things because Android Assistant will only list the apps that can be safely moved to the SD card. Some built-in phone apps must stay on the phone's internal memory to keep working, and those cannot be moved and won't be shown by the APP2SD tool.
The Android Assistant also has a "Cache Clear" option on the Monitor tab that helps free up internal memory on your phone when you run it (cache clear). The app (Android Assistant) may tell you it needs access to stuff so it can clear the cache. Do what it says to give it access, then go back and tell it to clear cache and it will free up some more internal memory. Cache items will be refilled as and when each app gets used, so if memory runs short again, you might need to do this "as-needed".
I paid the cheap price for Android Assistant Pro so I wouldn't accidentally click on advertisements that pay for the free version. It find the app very helpful.
TIP: You can also set MANY apps to PUT their things directly to the SD card instead of internal memory! Yay! I did this with my camera app and it REALLY helps by having photos and videos sent directly to the SD card so I don't have to keep moving them around.
Jan 07, 2018 | Tablets & eReaders
My tablet has started running really slow and sometimes freezes up. How can I fix?
hi Debbie.
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet
How do I make my tablet run faster?Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authorityhttps://www.androidauthority.com/11-tricks-make-android-run-faster-414542/Search for: How do I make my tablet run faster?
or go to this link should help you out some more.
tablet running really slow Google Search
Nov 26, 2017 | Tablets & eReaders
Cant access you tube on my tablet.
hi Ross.
this is all i could find so not sure if it will help you out.
How do you fix my YouTube? YouTube app
  1. Restart the YouTube app.
  2. Restart your device.
  3. Turn off and on your mobile data connection.
  4. Clear the YouTube app's cache.
  5. Uninstall and reinstall the YouTube app.
  6. Update to the newest available version of the YouTube app.
  7. Update to the newest available version of Android.
Troubleshoot video streaming issues - Android - YouTube Help
Why my youtube video is not playing?
Too many cache and cookies. ... Therefore, users should pay the same attention to cache and cookies when your YouTube videos not playing Chrome, Safari, Firefox etc. Solution: Clear cache and cookies and then restart your browser to play YouTube videos again.
YouTube Videos Not Playing Problems Tackled! - MacXDVD
How do I fix my YouTube app?
Follow below steps:
  1. Disconnect from WiFi/ Mobile Data.
  2. Open Settings > Application Manager > YouTube.
  3. First tap on Force Stop, then clear data and clear cache.
  4. Do the same thing with Google play services. ...
  5. After completing restart your device.
  6. Connect again to WiFi / Mobile data.
Youtube Fix ' Connection to Server lost. Touch to Retry. - Tech Flix
How do I get YouTube on my tablet?
Enter the TV code on your phone or tablet
  1. Open the YouTube app on your phone or tablet.
  2. Select Watch on TV under the menu.
  3. Tap ENTER TV CODE, under the Link with TV code section.
  4. Take the blue TV code that appears on your TV and enter it on your phone or tablet.
Link your phone, tablet, or computer to watch YouTube on TV ...
if none of the above work for you or help you out go to this link and see if that helps you.
can access youtube on my tablet Google Search
Nov 21, 2017 | Tablets & eReaders
How can I clean my storage, I ran out of room!
You can release more storage room by going into Settings and then into Storage. Clear the cache to get more storage space. Some tablets have their storage divided into two partitions. The first one is usually 1 or 2 GBs. The second has the rest. You can go into your Settings and then into Apps/Applications, click on an app and see if there is a button to move the app from the tablet to the second partition, which can be named differently on different tablets (internal SD, external storage, SD, etc.) Move as many apps as are allowed. Know that apps that can be moved will not move the entire app, only a portion of it, but this will free up a lot of memory on you primary partition and often speed up your tablet. It is a good idea to leave some room (100-150 mb) on your primary storage partition, so you can download files. If it is too full, the tablet will not be able to download files.
May 03, 2015 | Tablets & eReaders
How do I remove demo mode off my tablet
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message.
Mar 26, 2015 | Acer ICONIA Tab A500 10.1 inch Tablet PC,...
Extremely slow
It may be that an App that you have downloaded is causing this issue. Please uninstall if not necessary. You can also reset the tablet back to original factory settings, which will erase all of your personal data, photos, downloaded Apps, etc., but will also speed it up and stop it from freezing. Please see above for how to perform a factory data reset.
Please also download the ES Task Manager from the Google Play Store. It's free, and with the tap of a button, will close all Apps running in the background, and also clear the cache. You can run this App anytime without losing any data.
Support Troubleshooting Guide
Mar 26, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
How do you reset the android tablet
Hello Pamela
Your apps store was got error you can clean the cache data of your apps store to make it normal.
Steps
1. Go to Settings
2. Go to Applications
3. Select Manage applications
4. Select ALL
5. Find the App Store and click
6. then press/click the Clear Data or Clear Cache
7. Then after that restart your tablet
Try to connect on Wi-Fi then start your apps stor. If the problem not solve that's the time you most reset your tablet.
Mar 03, 2014 | Archos 101 Internet Tablet 16GB 10.1"...
When I try to download an App, I get an ERROR that says: Error retrieving information from server. [RPC-S-5:AEC-0]. How can I get this to download apps?
Fixing RPC:S-5:AEC-0 Google Play Store Error
The Google Play / Android Market error retrieving information from server RPC:S-5:AEC-0 error message can be a bit of a pain, the RPC:S-5:AEC-0 error just randomly appeared on my tablet after it upgraded to a newer version of Android. However this is how i managed to fix the RPC:S-5:AEC-0 error with ease.
  1. Load the Settings app, click apps, then select "All"
  2. Next in the all apps view find the "Google Play Store" and click on it
  3. Now click "Clear Cache" (Not Data), then Force Stop.
  4. Next in the same app list find "Google Service Framework"
  5. Click clear data (Not Cache), then Force Stop
  6. Switch off the phone or tablet and turn it back on
  7. You should be able to download and update apps from the Google Play store once more.
Enjoy no more RPC:S-5:AEC-0 errors when downloading or updating apps.
Or Simply Go to settings/app.manager/all
Delete data + cache :
Google Play Store
Google Play-services
Google Services Framework
Hangouts
Market-feedback agent (important)
Then delete google-account(data/system/user/0/ fine the accounts.db file and cut and paste it somewhere else)
Restart the phone and then re-add google-account( paste your accounts.db file earlier to it's original location).
p/s~Your device need to be rooted to remove/delete google account without a factory reset.
enjoy and have a good day :)
Oct 15, 2013 | SVP Tablet PC Android WiFi A13
I have the IRULU 7" tablet. Everytime I go to download a game it has me accept etc. then as it starts to download it says ERROR: trouble communicating with server. But my connection streaghth is EXCELLENT...
If your application has stalled at "Starting download," please use the following troubleshooting steps to help complete your download:
  • Restart your device, then try downloading the app again.
  • Confirm there is connectivity to either wireless or cellular networks on your device, and contact your service provider if you aren't connected.
  • Try your download(s) using both wireless and cellular network connections, and ensure firewalls aren't blocking access to ports required for Google Play (TCP and UDP 5228).
  • Make sure you've cleared the cache and data of both the Google Play store app and the download manager. Here's how:
    1. Visit Settings > Apps on your device
    2. View All apps
    3. Select the Google Play store app, and then tap Clear data and Clear cache.
    4. Then, select Download manager and tap Clear data and Clear cache.
Sep 23, 2013 | Irulu 7" Touch Screen 2gb Android 2.3...
I cant get in the market
Try clearing the cache. Go to Settings, Apps, scroll over to All, scroll down to Google Play Store, then click Clear Cache.
Aug 30, 2013 | Android ZEPAD 10" Tablet Android 2.2
Shopnbc Zeki 7" Multi-TouchTablet Logo
42 people viewed this question
Top Shopnbc Tablets & eReaders Experts
The Scrivener
 Mike M
Mike M
Giulio Moro
Are you a Shopnbc Tablet and eReader Expert? Answer questions, earn points and help others
