Televison & Video Logo
A
Anonymous Posted on Apr 09, 2016
How to hard rest my Westinghouse 55inch TV it comes on but can't see anything and it want me do anything with or with out the remote I done something in the settings menu and this happens any help
Steve Oakes
Level 2:
  • Expert 234 Answers
  • Posted on Jul 30, 2016
Steve Oakes
Expert
Level 2:
Answers
234
Questions
18
Helped
90405
Points
788
5 Related Answers
Anonymous
  • 203 Answers
  • Posted on Nov 22, 2007
SOURCE: iLO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Anonymous
  • 260 Answers
  • Posted on Jun 20, 2008
This particular model of tv has a problem with the control board. This is a common problem with this unit. You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
Anonymous
  • Posted on Sep 27, 2008
I recently bought an ILO 32 HDTV with the same problem. I searched every site I could find for a solution. I finally found someone that gave me the direction to replace the Main Board for the TV. This is the board that you can plug your exteranl devices into, computer, dvd, HDMI etc.
The phone # to Digital Age is 909-974-2859. These are the people who can send you the part you need. Also the remote that I have is RC-500, which is the newest remote control for the new Main Board. I would suggest getting this remote.
The price of the board was $123.89 with $10.00 shipping. It only took 4 days to get the board from Ontario California, and yes they do speak english.
I removed the backpanel myself and then removed the metal cover over the Main Board. Remember to mark all of your wires and screws so you can put them back in the same location. The connections are all quick disconnects and the board is one piece. I had the board replaced and the back panel back on within an hour. All buttons working on the TV and the remote control, and the TV is working great with sound.
But I do not have the Manual......does anyone have the manual? I am willing to help anyone with a fix for their TV for a copy of the TV Manual.
I hope the information I have given helps in anyway possible,
Johnny
Anonymous
  • Posted on Jun 09, 2009
SOURCE: TV code
Philips universal remote , it have code for that tv..
http://www.urc.philips.com/
bshldn
Loretta Northcutt
  • 736 Answers
  • Posted on Apr 28, 2010
SOURCE: original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
2answers
Have a Techwood 55inch smart TV. It's just done a update but now the only sound we get is through the sound bar. Press volume up on tv remote, numbers go up but no increase in sound. Any ideas?
My TV has a setting to shut off the internal speakers. Like yours, if it is set to off, then I can turn up the volume with the TV remote and the volume does not increase, even though the volume number goes up. Maybe your TV has a similar setting.
2answers
Cual es el codigo de acceso para canales de tv LD-2240
C?digo de acceso para tv westinghouse, modelo LD-2240 , num de serie :6610120103391
4helpful
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
