Question about Epson Xp-400 Small In One
What does Printer in an Error state mean? How do I get out of it?
Makes copy fine off scanner. Won't print off computer at all. In fact one minute it's okay next it just stopped.
6ya staff
SOURCE:
Anonymous
  • 944 Answers
SOURCE: epson all in one (printer/scanner)
Here is the link for all the documentation, troubleshooting and drivers for your printer. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58773&prodoid=56291070&infoType=Downloads&platform=Windows If you go through the troubleshooting guide, hopefully you will find an answer - with the info you gave I had no luck, but the procedure is quite detailed, so you may have more idea what answers to give. The next thing to try is to uninstall and reinstall the drivers - on the link above you can download the latest versions. This ,may solve the problem and is simple enough to do (ask for more help if you have trouble with this procedure). The only other thing that maybe worth doing is to give the whole machine a gentle shake just in case the scanner carriage mechanism is somehow jammed - sometimes a shake or a slap can free this. Hope this helps, if not please post again :)
Posted on Mar 22, 2007
Basti
Edgar Allan Pagayona
  • 1447 Answers
SOURCE: Won't print but copies and scans
What operating system and is this on a network as a shared printer or wireless?
Download Epson net config from the website and run the program on all computer and configure it, make sure on the printer that ip is set to obtain automatically.
try this link as well
http://files.support.epson.com/htmldocs/cx11nf/cx11nfug/dwnh_7.htm
Posted on Apr 02, 2008
Anonymous
  • 10 Answers
SOURCE: scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Posted on Apr 01, 2009
Anonymous
  • 134 Answers
SOURCE: Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
Posted on May 03, 2009
Anonymous
  • 63 Answers
SOURCE: my cx3200's control panel reads scanner error. I
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Posted on Feb 10, 2010
Solving scanner error 5
If you are using windows - go to Printers / Devices and uninstall the printer
Turn the printer off and wait a couple of minutes
Now turn on the printer
Now add the printer in windows again and it should work
Jun 30, 2017 | The Office Equipment & Supplies
Want copy ---comes up unrecoverable scan---ties up machine for 5-10 minutes---LEXMARK 5600-6600---IT also makes a knocking sound. until red light goes off and green light comes.on---1st time happened...
Unrecoverable scan error is a hardware problem. Features affected by this error are scan, copy and fax. Recommended action is to contact Lexmark technical support for assistance.
Sep 20, 2010 | Lexmark All-in-One Printer with PictBridge
Printer not Printing
well this is the software issue till i can understand. to be sure that it is purely software issue try to copy from your printer itself and see if that is not the printer's fault.
if its not then:
Remove printer's USB cable from your computer
delete the Printer's Icon from your control panel/ system preferences> Printers and faxes/ printers
now uninstall the software of kodak and reinstall the the software from www.kodak.com/go/esp3downloads
after software installs then plug your printer back in and wait untill it get installed on your system
try to print it again and see if you can print
May 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner and coping not working.
Not too long ago I had the very same problem. After TWO days with Kodak support over the phone they had to send me a new printer. It has to do with the printer that only they can repair. Reinstalling software will not fix the problem, at least in my case. Hope it works out.
Feb 22, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Scanner error
usually this means that the scanner electronics has failed. If you can print from the control panel try printing out a configuration page and let us know what the error codes are.
Mar 25, 2008 | HP LaserJet 3380 All-In-One Printer
Hp psc 1350v WILL NOT COPY OR SCAN
sounds like the scanner/copier engine(same device, by the way) has gone way UnHappy. time for a service call or a recycling effort on that machine..it's a major component..and buried deep inside machine.
Feb 19, 2008 | HP PSC 1350v All-In-One InkJet Printer
Epson Xp-400 Small In One Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
