Do a system restore, this will remove any updates. If the software still doesn't work it wasn't the update.
If it is the update then there's not a lot you can do about it, till Microsoft fix the problem. You could tell the Software company or Microsoft.
That's why only 20% of the population have switched to Windows 10, even though it WAS free. It's not any longer.
You can't get rid of bad updates!
SOURCE: PA Projects will not convert to JPegs. Cannot cut or copy image.
Find a Tech and use www.CrossLoop.com
SOURCE: every time I try to boot up print artist platinum
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
SOURCE: print artist platinum 22 does not want to install
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
SOURCE: Is Print Artist Platinum Edition
Print Artist Platinum Edition version 22 is compatible with Win 7.(x86 X64)
You can check this @ Windows 7 Compatibility Center
Hope it helps.
