Question about Maytag Washing Machines
Clothes stuck under agitator in Maytag Bravos MCT. Removed bolt but agitator will not lift up. Any tricks?
It happened to mine also. Nothing came out of a pocket, either. A scarf worked it's way in somehow and got caught up in the gear that moves the agitator. Lift off the center cap, loosen and remove the 11mm bolt, then lift the agitator straight up... If you don't lift straight up from the middle it will seem like something else is holding it.
Posted on Nov 16, 2019
6ya staff
SOURCE:
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: clothes stuck under the agitator
you really have clothes stuck under the "wash plate" it has almost zero clearance and would be very hard to get something stuck under the wash plate.
if you do have something stuck, then remove the 1 1/2 inch cap in the center of the plate, then a 7/16th bolt that holds the plate down. then grab the wash plate and lift up to remove it.
next time check your pockets and dont let this happen again, it could ruin the outertub by cutting a hole thru it and then leaking.
Posted on Jan 06, 2009
Anonymous
  • 212 Answers
SOURCE: agitator not agitating to wash cloths.
remove top of agitator remove plastic cap inside agitator housing. remove 7/16 in. bolt. lift out agitator
Posted on Jun 20, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Lifting the top
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
kdrake84
Keith Drake
  • 262 Answers
SOURCE: how do I lift the
The link listed below will show you a diagram of your units Motor basket and lid parts.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWB300WQ1/3048/0153200/W1003175/00003?blt=06&prst=0&shdMod=MVWB300WQ1
As you can see (click on view full size) part number 6 (impellar or agitator) is held down by only a bolt,part number 2 and a washer part number 3.
Simply remove the bolt and remove the impellar (agitatior)
If you have any other questions or concerns please post.
If this information helped you please consider giving us a 4 thumbs up for our rating.
Thanks in advance and Thank You for using FixYa!
Keith
Posted on Feb 20, 2011
Pualpsps
  • 29 Answers
SOURCE: I have a brand new
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
What is the gentle wash on Maytag Bravos mct ... cold wash and handwash DO NOT seem gentle, I feel it is ruining my gentle washed clothes.
On my Maytag, gentle cycle means less agitation strength and slower speed. The rinse cycle centrifuge is not as fast and doesn't last as long. Hopes this helps.
Jan 28, 2018 | Maytag Washing Machines
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
My Maytag washer ripped my clothes. They have holes in them, What could be the cause
If it is a top loader it is the clothes getting pinched at the base of the agitator. Undo the knob on top or the bolt under the fabric conditioner container, lift off the agitator, check underneath, and replace it, making sure it is seated well
If it is a front loader, I had the same problem and it needed a new drum. The ridges around the drum had some sharp bits that were cutting and tearing the clothes as the clothes were sliding over them.
Nov 14, 2016 | Maytag Washing Machines
Is there a reset on a may tag bravos mct washer
Top 565 Complaints and Reviews about Maytag Bravos
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.2 - ‎241 votes This Maytag Bravos HE machine has the poorest design! ... So disappointed in Maytag - I have a 2013 Bravos washing machine that if I had it repaired again (less .... Called Maytag because my owner's manual stated I had a 10 yr warranty.
Jul 26, 2015 | Washing Machines
I have a Maytag Washer Model LAT9206BAE, I have cleaned the washer but my clothes are still getting a lint like substance on them. Is there a screen or something on the discharge that may be blocked.
There is no filter. You may have something that is hung up under the agitator. To remove the agitator, remove the fabric softener cup, then the bolt that holds the agitator on and lift the agitator out.
Nov 22, 2012 | Maytag Washing Machines
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
I have a dart stuck under the agitator. How do I remove the agitator to get it out?
pull the top cap off down insde the agitator is a bolt. it is a 1/2 inch or 7/16 inch in size. remove the bolt and lift up agitator.
Apr 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Clothes stuck inbetween basket on Maytag Bravos washer
This is for several brands ... not just the Bravos.
Based on your description, it looked like you needed to take the center agitator out first .... to then access the inner basket bolts ... remove the inner basket to then get to where the clothes are ... not a real easy task
capture-ce5c5tqeeiqfekdpzmvievq3-1-0_0.png Good luck on your troubleshooting
Jan 25, 2018 | Maytag Bravos 3.8 Cu. Ft. Washer
I think my daugther's retainer is stuck under the agitator. How can I get it off to check?
If this is a Maytag Atlantis model washer, just follow these steps to remove the agitator:
1. Remove the center post cap and softener dispenser by pulling it off.
2. Locate the agitator bolt under the center post cap and loosen.
3. With the agitator bolt removed, lift up on the agitator by grabbing the bottom flange.
If the model number is incorrect, please post back with your correct information. I hope this helps you.
Nov 11, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Washing Machines Logo
5,112 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
