Dishwashers Logo
Vanessa kiop Posted on Apr 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why can't I get the lights to go on to start it?
When I open the door, just the little lock lights up
  • Official Brand Answer 4,342 Answers
  • Posted on Apr 19, 2016
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467852
Points
5907
Hello Vanessa, thanks for your submission!
I understand that you are unable to operate your Electrolux dishwasher and the lock symbol on your control panel is on. This means that your dishwasher control has been locked and you would need to disable it in order to start the dishwasher. If you could provide me with your model number I can explain how to disable the control lock. You can locate the serial tag (which lists your model number) on the inside left hand wall of the dishwasher. With that information I can assist you further. -Matt
5 Related Answers
Anonymous
  • 111 Answers
  • Posted on Jan 02, 2009
SOURCE: ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Anonymous
  • Posted on Jan 19, 2009
SOURCE: lock light is on
The lock only locks the buttons (childproof), hold it 3 seconds and it will go out.
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 26, 2009
SOURCE: Electrolux Dishlex Door wont shut
spring it catch still working you just may need to replace it
Anonymous
  • Posted on May 07, 2009
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Anonymous
  • 632 Answers
  • Posted on Aug 31, 2009
SOURCE: electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
2007 Dodge Caliber SXT dome lights randomly come on and stay on, door locks go crazy, then battery dies??
bad wring in the doors
and happens,
find the door that is bad and remove cards and see the damage.
to wires.
doors work ,key off. and if true, can short and drain any battery.
for emergency exit.
door switches bad. dome too switch, windows too and locks.
all that must be checked for good and bad
any shop can fix this, electrics,+ auto.
1helpful
Reset computer
If you pushed the car by the door itself or swung the door open hard, you could ha e stretched the door harness and pulled wires apart. There is a little accordian styled boot that 'protects, the wire loom leading to the driver door electronics. I wonder if you have noticed your alarm horn doesnt beep when locking the doors from the remote. Or you can only lock and unlock the driver door only from the driver door. If thats the case there may be an open in the wires leading to the door lock actuator; which controls things like lock/unlock functions of all doors and windows, door warning lights, etc. Have the harness repaired
Garagedoor opener fixed on wall will will open and close door. but will not work from the remote. problem my be because little green light flashing permanently. what is solution
Your opener is in the lock mode. Press and hold the lock button on the wall control for 3 seconds. This should stop the flashing of the light.
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
1helpful
2answers
When i open my drivers door my radio and dash lights stay on but they turn off when i open the other 3 doors ???2003 trailblazer
The door sensor needs adjusting. It may be loose.
Loosen the lock nut on the pushbutton sensor in the door frame.
Unscrew the sensor a little and re-tighten the lock nut.
1helpful
The door lock isn't engaging.
you may have bent thr hing on the door if you lean on them on top they will bend try a little lift on the door then close
2helpful
"Door Ajar" signal on dash panel stays on even when doors are clo
there should be a switch mounted( or more than one) in the door jamb that tells the car when the car door is open...i will probably look like a little plastic plunger...might be broken off or bad internally
10helpful
3answers
Door lock 2004 jetta wagen
If remote locks and unlocks driver door but does not unlock passenger doors,then follow the advice above:
Get in the car using the key to unlock the doors. From the passenger side lock and unlock your doors using the button on the passenger door. Get out and the remote should now unlock all the doors with 2 presses.
Worked perfectly for me after several other suggestions (and dealer) failed.
Door lock
Check for loose wires in the door lock; or replace door lock.
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
