Good job, man! There is another choice to take, you can directly activate your windows permanently and you will not be troubled with this problem. Just get a genuine key from http://www.instructables.com/id/Step-by-Step-Upgrade-Process-From-Windows-7-to-Win/and you can get this done. What's more, the price is very low.
SOURCE: trying to install videocam suite 1.0 on xp home edition
Try right clicking on the installation .exe and clicking Properties. There might be a tab that says Compatibility. Click that and choose XP or XP/SP2 from the list and press apply.
try running the install now..
Hope this helps
Season's Greetings!
chris (ziraffa)
PS Here's the updater file for Videocam Suite too, which will be handy if you do manage to get it installed...
http://panasonic.jp/support/global/cs/soft/download/videocamstuite_v10.html
SOURCE: VideoCam suite 1.0
Just install the Software suite, disregard the message. it may be because the when the suite was released the current SP released was SP1 or 2, when you connect the camcorder make sure that the camcorder settings are set to PC connect (or whatever setting for a PC connection), make sure that the ac adapter is connected.
Hope it helps
SOURCE: I have SDR-H60, installed the videocam suite on my PC but cant us
The software will work only if you attach the camera to the electricity cable comes with the camer...The software will not work using the battery.
SOURCE: videocam suite v1.0 download for a Panasonic SDR-H280
I've successfully downloaded & install the videocam suite 1.0 + update from here: http://www.brothersoft.com/videocam-suite-297215.html Thanks to Google!
SOURCE: non compatible with windows 7
Version 2 is compatible with Windows 7:
http://panasonic.jp/support/global/cs/soft/download/vcs20ee_w7.html
I had my Panasonic video camera installed on Windows 7, using the supplied disc 'videoCam Suite 2.0'
Had a rebuild of PC and had to re-install all programmes, but this time using Windows 10, when I insert the disc, at first it says "install shield wizard preparing to install" , and then another window comes up which says, "This application does not support this operating system, Installation will be terminated."
Is there anyway I can install my video camera on Windows 10, so that I can download videos to my PC.
