How to start fax action after fax number is typed in
SOURCE: Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
SOURCE: Fax Call Report - identification number not appearing
I have no experience with it but here are the manuals
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=uk&docIndexId=64902&taskId=101&prodTypeId=18972&prodSeriesId=1140783
SOURCE: FAX TRANSMISSION
I have had this issue as well faxing to any area code in general outside of my own. The only thing I found to work was manual faxing. This comes from the manual.
Dial manually from the handset
1. Load the document into the ADF.
2. Call the recipient on the handset.
3. When the recipient is ready(when you hear the fax sound), press Start Fax on the product control panel.
SOURCE: SENDING A FAX TO MULTIPLE RECIPIENTS AT ONE TIME
Type in the first fax number, then hit the Enter key (the check mark), then type in the next number, hit the Enter key, and so on until you've gotten all of your numbers entered. Then hit Start Fax.
