Sony Playstation 3 (PS3) Console Logo
d
duane taylor Posted on Apr 13, 2016
I need my 6 digit passcode - Sony Playstation 3 (PS3) Console
1helpful
2answers
How do I activate my new Apple 6s iPhone?
depends on your country and provider you need to delete and re ask the question.
generally you call your provider and look up sim and or ime number under settings and about and read those numbers to your service provider and they activate the device on your account
Set it up with thumb print when Iopened it up wont let me in without 6 digit passcode which I don't have
Well, when you first set up your IPad you had to create a passcode to get in. If you can remember what your passcode is click the link here and reset it. Forgot passcode for your iPhone iPad or iPod touch or your device is...
Can I make a new password
Yes, you can
Use passcode with your iPhone iPad or iPod touch
Set your Passcode
    1)Go to settings > Touch ID & Passcode. On devices without Touch ID, go to Settings > Passcode.
    2)Tap turn passcode on
    3)Enter a 6-digit passcode
    4)Enter passcode again to confirm Change passcode or passcode settings
    To change your passcode or passcode settings, go to Settings. Touch ID and passcode. On devices without touch ID, go to settings > passcode.
Nov 19, 2015 • Cell Phones
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
NOTE:
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
What's the passcode for p9725b?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 25, 2012 • Cell Phones
1helpful
2answers
Iphone new passcode I forgot my passcode
ur defalt phones codes is 12345 or 00000 u can use it
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
