SOURCE: i m using tally7.2 multi user i m getting internal error memory access violaion exiting tally
Dear navin12,
I also got this same problem in my office, first time i solved this problem through restore the XP to Previous restore point. second time this problem came different machine in that machine restore point not worked, I tried all the ways but no use, finally it will work when i login as different Domain user in that machine, I couldn't solve that problem in that particular user.
SOURCE: corruption of tally 7.2file
Exiting Tally!
File Damaged
File:C':Tally7.2\Data\009\manager.500
Size 180180
Position: 180352
Charj : 128 (done128)
SOURCE: Sub : TALLY 7.2 error
exiting tally! \r\ninternal error
software exception c0000005
(memory access violation)
SOURCE: Exiting Tally
rewrite tally data press ctrl+alt then R on gatway of tally then salect damage comp and press y
SOURCE: EXITING TALLY!! Internal Error. Contact Tally
My tally 5.4 not open when to try open tally when see exiting tally! file not found. Please give the solution immediately
