Sentry Fireproof Safe Logo
L
Linda munson Posted on Apr 14, 2016
Know combination, but every time I enter it, why is there an error light?
Tony Faulkner
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Oct 24, 2018
Tony Faulkner
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
1013
Points
5
If you repeatedly get an error code when entering your combination I would first ask if your batteries recently went all the way dead ? If yes then possible that the data for your combination was lost. In your user manual for your safe is a factory code for your safe. If you did not change your factory code when you set up your safe then this will work to get you into your safe. If you did change the factory code and do mot have that number either then the only way to get into your safe is to contact Sentry Safe customer ssrvice. They will be able to take care of you but it is a process.
How do I change combinations Bulldog Cases Car Safe when they revert to default?
Changing combinations can be done from the reset button. It exists at the topmost part of the device. To reset - Hold it down for a few seconds until the light indicates green, release and enter your new preferred code. Repeat the procedure until the light goes red and re-enter the new code. Then repeat for a third time until the light gives you five blinks. TO know A depth review about this product You much visit here: Bulldog Cases Car Safe with Key Lock Review
Whirlpool dishwasher model# gu2200xtss3 normal light flasing all the time turning power off does not help in a few minutes back on flashing
The light blinking is an error code--usually it will blink a certain number of times, pause, then blink another sequence(ex. 4 times, then 3 times)in a binary error code. There is a chart in the service manual to decipher the code(s) and locate the issue. It could be anything from a heater circuit failure to the drain pump being jammed. Try to see how many times the light blinks, and which ones blink--there could be, on the first part of the sequence, normal light, then, 2 or 3 lights blink-- I need to know which ones are lit. Thanks! You can try to look up the light combinations on the net with a search for your model number and error codes.
How would i know if i hav a cpu problem?
When you start your computer your computer you should be able to enter the BIOS/CMOS by pressing a single or combination of keys and see your CPU setup -OR- if your computer beeps at you several times and displays error codes before loading your operating system.
Trying to open safe but each time I enter it beeps with a red light
When you change batteries the combination that you programmed into the the Sentry Safe will delete and you will get the red light error signal. At A1 Locksmith Service we recommend that you use the original master code that came with the Sentry Safe. If you can not find your owners manual with the master combination. Addtional help can be provided at A1 Quality Safe. (650) 240-5505
E-3 ERROR MesSaGe IS SHOWING UP EVERYTIME I ENTER ANYTHING.
It sounds like you will need to Reset it. The modern method is using a combination of key presses. In the old days there was a hidden recessed red button hiding under the Total, or Sub Total button. Pressing that button clears all memory including X and Z Totals.
https://www.google.com/search?q=uniwell+system-16+series+cash+register+reset+button
Safe will not open
Once you get the error light that means you are entering a user code that was deleted when the batteries went dead . Simply use the master code in your owners manual to open the safe. Reprogram new user code instructions bottom of this page.
2helpful
3answers
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
I have the Edie Bauer by Audiovox DVD player but no manual or remote .what is the access code with a universal remote?
it's time for trial and error thing.i assumed you already know how to enter the access codes.try different three combination numbers including zero.like 000,001etc.
1helpful
Error light comes on when keying combination code
Try new batterys ,also sometimes if too full ,you will have to hit it hard to get the stuff off the lock bars that keep them from moving .
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
