Canon imageRUNNER 2520 Laser Multifunction Printer Logo
A
Ahmed Abdullahi Posted on Apr 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
Joseph Coppeto
Level 3:
Master:
  • Master 360 Answers
  • Posted on Apr 14, 2016
Joseph Coppeto
Master
Level 3:
Master:
Answers
360
Questions
0
Helped
150040
Points
2623
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
1helpful
2answers
3helpful
2answers
Canon 2318 **E000007-0000 restart the machin. if problem persist call service rep
It is an error for fuser flim/fixing flim torn so the sensor detection e7.Please change the defecting fixing flim .I hope the error fix
2answers
9helpful
3answers
As soon as I started My ir3300 machine , with in few sec. screen shows error code E000000-0000,
Hi Sir My name is Sreenivas
I have facing problem with E000602-003, please tell how to rectify this problem, thanking you sir
78helpful
6answers
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Photocopier iR2016J is showing an eror message -system error E007
that mean ur coopier fuser flim is damaged. if ur fuser flim damaged in right side corner replace new one.
366helpful
10answers
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
4helpful
Canon image runner error code E000000-0000 solution
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
112helpful
12answers
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
2helpful
3answers
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
old marine
old marine
ZJ Limited
ZJ Limited
