My 42 Olevia TV screen does not show the xbox playing even though I can hear it?
I have switched hdmi cables and still no screen. BUT when I go to the menu eye see all the menu options, so the screen works. any thoughts? I'm puzzled!
is the normal tv input for high definition? Don't understand that term. I have a dish receiver, when I use an hdmi cable I get a really nice picture even with Roku
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Hook your X Box into the Receiver HDMI input with your HDMI cable and another HDMI cable from the HDMI out on the receiver to the HDMI input on your TV.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
