When I print from the COmputer it will print 1-4 copies and the a fault error occurs 124-373 How do you fix this Xerox techs are scratching their heads- HELP!
Xeroxhttps://www.support.xerox.com > en-us > article
Jan 19, 2021 - Resolve the Duplicate IP Address Conflict With Another Device on the Network. Manually Set a Static (Permanent) IP Address on the Embedded ...
Copytechnethttps://www.copytechnet.com > ... > Xerox
Aug 30, 2014 - This error code means your bustled Fiery or Creo network controller do not communicate with the machine. Check all cable from net controller to ...
Printcopy.infohttps://printcopy.info > code=027-452
Code: 027-452; Description: IPv4 Duplicate Duplicate IPv4 addresses detected upon startup. Causes: Remedy: 1 At the printer's Control Panel, press the Menu ...
Fault Code 093-314: Yellow Dispense Fault. Fault Code 093-314 occurs when an error has been detected while dispensing Yellow Toner to the Print Engine. https://www.support.xerox.com/en-us/article/en/1134533.html
https://www.youtube.com/watch?v=nkN1v1LdTUA
This error in Xerox 8560 printer occurs when Cyan ink melt heater is on but the ink is not dripping. To troubleshoot this issue please make sure that you are using genuine Xerox ink. If yes then run Clear ISC Fault test to clear the error. The Clear ISC Fault is located in the Internal Diagnostics Function menu.
Also check for broken or wrong type of ink sticks. After this try clearing the fault by running Clear ISC Fault option. If the sticks are also fine then run the appropriate Ink Melt (1,2,3,4) Heater test. If the test fails then there is an issue with the print head.
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
The 37 series faults are usually due to the failure of one or more heaters in the print head. Usually a comparatively inexpensive fix if its just the electronics module(part no:119649580). You will definitely need a tech's assistance to fix it. If the printer is under warranty they XEROX should do it for you free of cost. Hope that helped.
Use the following procedure to troubleshoot Error Codes
009-910 through 009-913
1. Check the installation of the Print Cartridge.
2. Clear the Tech Rep Fault for errors 009-910 through
009-913 (see instructions below).
3. Try changing the indicated Print Cartridge.
4. Check for an open wire or poor contact between the
Print Cartridge and the Engine Control Board.
a. Yellow, J-151 to J-405
b. Magenta, J-152 to J-405
c. Cyan, J-153 to J-405
d. Black, J-154 to J-405
5. Replace the engine control board
NOTE:
Before troubleshooting for an open circuit (Step 4) or
replacing the Engine Control Board (Step 5), clear the Tech
Rep Fault for any of these codes first using the following
steps:
1. Enter Service Diagnostics.
2. Highlight NVRAM Access and press OK.
3. Highlight Clear Tech Rep Faults and press OK.
4. Highlight link codes 009-910 through 009-913 and
press OK.
Hope my info solves your problem.....
Thanx for using fixya......
