Good Afternoon Gerald, thank you for your post!
I see that your Frigidaire refrigerator is only dispensing crushed ice not cubed ice. Your solenoid (which tells the dispenser crushed or cubed) might be frozen. You can defrost the solenoid by disabling power from it for at least one hour and then restoring power. If you continue to experience this issue you may need to have the solenoid replaced or the control panel and I would suggest having a professional technician out for proper repairs. Good luck with your refrigerator! -Matt
SOURCE: crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid. The solenoid is bad. When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out. First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down. You can take out the ice bucket and press for cubed ice. You should hear a loud clunk noise. If not then you know the solenoid is not working.
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
SOURCE: Ice maker only makes crushed ice, no cubes
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
SOURCE: Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
