After changing new ribbon it appears this code 5007
SOURCE: zebra printer ribbons
Try using this manual for the Datamax ( don't think it should be that much different) Page 28 http://www.posguys.com/download/DataMax-I-ClassManual.pdf If not then try this one http://service-manual.net/ashop/catalogue.php?exp=&cat=294&shop=1
SOURCE: i have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
SOURCE: keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
SOURCE: I want to change the
Thermal printers don't use ribbons or ink. They transfer images/text with heat on to special thermal paper.
