Question about Samsung Galaxy Tab 2 7.0
Wont power on with plug in - Samsung Galaxy Tab 2 7.0
    Sergeant:
  • 213 Answers
Could be a bad cable, bad power supply or bad the micro usb port? Just a thought.
Posted on Apr 18, 2016
6ya staff
SOURCE:
How do i fix my proscan tablet that is stuck on android screen
Try a power reset by pressing the power button for 30 seconds with your device unplugged, then plug in your device and leave it on the charger for a few minutes, then press the power button again for 30 seconds while plugged in.
Sep 30, 2016 | Tablets & eReaders
My tablet wont turn on only if it is plugged in..unplug it and it goes off
Seems like the battery is disconnected! That is why it turns off when mains power is removed!
Oct 28, 2014 | Skytex Technology Inc. SKYPAD SP725 7-Inch...
Wont turn on
Reboot by holding power button and pressing start button. Check to make sure Nook is charging. Cord that plugs into Nook may be loose in port. Try wiggling and pressing power button at same time.
Apr 22, 2014 | NOOK HD 9 Tablet
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
(enter BootLoader)
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
My galaxy tab 2 7.0 wont reboot. when I shut it off and turn it back on it wont go past the samsung logo. I have tried to plug it in, it shows the battery icon and its full. I hold the power button down...
At frist turn off your smart tab&then press [(Volume+)+home key] on that time you have to press power key again and again.then you get cwm recovery.then select update from sdcard by using vol - key and click it by using home key.then select your zip file which is dwonload you before for root your phone.
Thank You
-Mitin Sakib
Aug 27, 2013 | Tablets & eReaders
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
My galaxy tablet GT-P7510 wont turn on its fully charged
Hold down power up button until it starts. It can take up to 30 seconds before it restarts.
Sep 29, 2012 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
My laptop wont connect to the internet...it connects to the router but then wont connect to the internet and its not the router or modem wont connect to a wired connection either
I would hook your laptop up directly to your broadband modem and bypass your router to rule it out. Plug the network cable from your modem into your laptop. Unplug the power on your broadband modem and plug it back in. Restart your laptop and see if you get on-line.
If you can...your router is the issue. If you cannot....I would check with your internet service provider before troubleshooting further.
Jun 04, 2010 | Gateway CX2726 Tablet PC
Samsung Galaxy Tab 2 7.0 Logo
41 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
