I punched the PTO button down. set brake off and on several times. Bounced on the seat. Any other interlocks?
SOURCE: riding mower does not seem to be getting gas
yeah.. the carb needs to be cleaned and rebuilt that is an easy job so if your a DIYer this will save you loads of money. just buy the rebuild kit..good luck
The safety switch beneath the seat is only one part of the several interconnecting safety features of the modern riding mower. If the system works properly, you must be seated for the mower deck to operate. The tractor will continue running with the Power Take Off disengaged if the parking brake is set before the operator leaves the seat.The seat switch consists of two electrical contacts normally separated by an air gap. A spring creates an open space between the two contacts. Mounted between two plates, the switch's spring compresses under the weight of the person sitting in the operator seat and completes an electrical circuit. With the switch closed the tractor's ignition system can be switched on with the ignition key. If the operator stands, the spring forces the gap open and interrupts the electrical ignition circuit. The safety circuit allows the riding mower motor to continue running if the PTO is not engaged. When the parking brake is set a second switch in electrical parallel with the OPS closes. This bypasses the safety switch under the seat. If the operator stands, the parking brake switch still completes the ignition circuit.The mower blade turns only when the PTO engages. If the operator should leave the seat with the blade turning and under power, injuries could result. The mower blade would even continue spinning at full power if the machine overturned. To prevent this type of accident, engaging the PTO deactivates a connection in the original circuit and completes a second circuit in series with the OPS switch.
If the operator leaves the seat with the PTO engaged, the ignition interrupts and the machine stops. Until the PTO is off, no combination of settings will restart the mower.
Yes, electric PTO is punched down, brake is set. I assumed it ran out of gas as it sputtered just a bit as it died. For that reason I did not attempt re-start until gas tank was refilled. No click, nada, nothing.
It's possible the battery is dead and your alternator isn't charging. Check for voltage
If you have power at the battery then you need to chase it til it stops. Could be one of the sensors gone bad, one way to fix is to bypass until you get the replacement part. If you do bypass a safety interlock disconnect battery when not in use.
