Question about Winchester Model 94 Short Rifle .30-30 20 Inch Barrel Deeply Blued Wit
Hello, I recently aquired a colt 1866 repeater. It is in perhaps a ^0% resolve, missing screws and the hammer is locked to the rear. I'd like to find a parts list and an owner's manual. Can you help?
What identifies the caliber? I'd like to bring it to a functional status, At-least mechanical.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
    New Friend:
Are you asking about a weapon or sewing machine? Sorry, new here, but have knowledge about firearms... WEPUNGUY0326
Posted on Apr 20, 2016
  • Andrew Taylor
    Andrew Taylor Apr 20, 2016
    Rifle. I just changed the category.
  • Andrew Taylor
    If Don replies back you will get a notification to your email and also next time you log in here.
    I have been here a while. Welcome :>)
    Top Expert:
  • Winchester Master
  • 29,781 Answers
Are you sure this a Colt and not a Winchester?
Calibre should be marked on the barrel or the action somewhere. There are special Colt and Winchester Forums online. Parts are available. The condition of the barrel with decide whether you can fire it or have it as a wall hanger.
Please reply back as a COMMENT.
Here is the info that makes me believe it is a Winchester.
http://www.bing.com/search?q=colt+1866+repeater&qs=n&form=QBRE&pq=colt+1866+repeater&sc=1-18&sp=-1&sk=&cvid=244CB6674F584B7694B3B4E1C5B5BD87
Testimonial: "It is a round barrel colt with a ser@ 2811 after removing the rear stock. Colt is on the barrel. Based on this ser @, I know it is a 1866.Blued not a yellowboy and is lever action"
6ya staff
SOURCE:
Rear wheel locked up
better get that wheel bearing replaced soon . It is going to fail you eventually and perhaps kill U and or someone else .
Apr 23, 2015 | 2004 Toyota Avalon XLS
Need a Replacement Needle Clamp for a White 1866
try these 2 sites,, ask them by calling them or email them
about the needle clamp screw
sewvacdoctor.com
a1sewingmachines.com
Sep 21, 2012 | White Sewing 1866 Mechanical Sewing...
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
Cannot get oil plug off of oil pan to change oil
Hello, dont mean to sound rude but double check to make sure your on the right screw. The screw should be towards the bottom of the oil panpossible at a slight angle to drain the oil. No special tools are needed normally a socket set will get the job done not exactly sure on the size. Try some locking pliers, lock it tight as possible around the screw and tap on the the handle with a hammer or somethin solid. I recently had the same proble with my oil pan screw thats how I got it off. Replace the screw once it comes off. Hope this is helpful.
Mar 29, 2010 | 1996 Audi A6
Chuck is locked open
you have three jaws in your chuck, one of them will probably have a small burr on it causing it to stick.
try this...
tap the chuck with a small hammer then try to use the chuck key gently in the opposite key hole to the hammer blows. turn chuck though 120degrees and repeat.
if this does not work chucks are fairly universal and easily replaced (i would recommend a keyless jacobs). you can get the old one off by removing the ph2 (phillips) machine screw inside the centre of the chuck... be careful!! this screw is usually soft and counter threaded... when screw removed bash off the chuck with a hammer and cold chisel...
good luck
Oct 23, 2009 | Dewalt 1/2 Hammer Drill DW511
IBM 6400 missing decimal...
is there print missing??? if so the hammer fret in that location probably (90%) needs cleaning as dirt can get between the fret, it only takes the smallest amount of debris to stop fret working, you need to remove hammer bank to do this, fairly simple to do just lots of screws. the only thing to check when reinstalling hammer bank is that you pull it towards you ( front of printer ) before tightening the 3 screws, this is to be sure the gap between hammer bank and platen is roughly correct. there are 2 small grub screws at each end of platen to adjust this gap if you need to.
Aug 06, 2008 | IBM 6400 Matrix Printer
Winchester Model 94 Short Rifle .30-30 20 Inch Barrel Deeply Blued Wit Logo
125 people viewed this question
Top Winchester Optics Experts
james laughton
james laughton
Colin Stickland
Colin Stickland
Fahr Quad
Are you a Winchester Optic Expert? Answer questions, earn points and help others
