When I try to charge to my phone I get a message that states: Charging paused battery temperature too low
Please simple replace battery and enjoy life. :)
The Samsung cells have four contacts. Two are for the voltage (sometimes marked as + and -) and two are for the temperature sensor. If the sensor is not communicating, the phone will detect an error and report it as low temperature. Try using a new cell and see if the message returns. If not then the old cell has a bad sensor. But if it returns, check that the four golden spring contacts in the phone are good, not bent, and the same length. If one of the contacts is bent, have it fixed.
SOURCE: My Samsung SYNC SGH-A707 will not charge
this is my 2nd phone and they both stopped charging...my batteries are ok. What can be wrong with the phone and how can I fix it?
SOURCE: Samsung SYNC Charging issue;
Just had a rand new samsun u900 soul deliveredand this has the same problem. Has anyone found a fix for this?
SOURCE: samsung sgh-a737-charging paused. phone temperature
i also got the same error...in my case i checked through my data cable,and it started charging......my charger is not working properly,u also can try,
SOURCE: I just bought a samsung phone but it is showing
I just bought a samsung phone but it is showing charging paused because your phone temperature is too high or too low what to do pls help?
SOURCE: Charging paused. Battery temp. too high or too low
In my technical experience
this occurs mainly in the samsung mobile phone
it is not because of your battery.it is because one of your ic chip is being damaged......you need replace it.you can touch the phone internal chip and see which one of the chip is getting more heated up..you need to replace it..can you please tell me your model no.?so i may help you in chip replacement.
