You need both an output from whatever it is you want sound from, as well as an input to your amplifier.
The source could have "audio out" sockets, or possibly a "headphone" socket.
The amplifier may have an "aux" input, or another input for something else that is not in use. You could edit your question and name the inputs on the amp. and outputs on your source to aid in getting advice, possibly also identifying what type of sockets are fitted.
The "audio out" would be a "line level" output, but the "headphone" output is likely fairly low level. It could still be high enough to drive into an "aux" input, worth a try.
You need suitable cables with end plugs to suit each end of the connection.
