Sansui 19 in. LCD TV Logo
Remove back panel to reinstall cable connector
1helpful
2answers
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Factory stereo not working and needs replaced. how does dash come apart to do this
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove cup holder.
  3. Remove trim panel above cupholder by pulling straight out.
  4. Remove center instrument panel trim panel.
  5. Remove screws holding radio to instrument panel.
  6. Pull radio rearward to gain access to the back of radio (RADIO). CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
  7. Disconnect the antenna cable by pulling the locking antenna connector away from the radio (ANTENNA TO RADIO).
  8. Disconnect bolt holding ground strap to the radio (if equipped).
  9. Disconnect the wire connectors from the back of the radio.
E260MV. How do I open it up to replace cable connector?
i have a 26" vizio model E260MV with no screws on back panel can someone assist please/
2helpful
2answers
I need to replace a blower motor on a 1998 GMC Sierra 2500 6.5L diesel. Could you tell me how to go about it, how much of the dash do I have to remove? Thanks
To Remove:
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment from the instrument panel.
  3. Remove the front screw from the right door sill plate.
  4. Remove the right kick panel trim.
  5. Disconnect the electrical connectors from the powertrain control module (PCM), as needed. Remove the PCM and mounting bracket if equipped with a diesel engine.
  6. Disconnect the electrical connector from the blower motor.
  7. Remove the bolt from the right lower instrument panel support.
  8. Remove the blower motor cover.
  9. Remove the blower motor cooling tube.
  10. Remove the blower motor mounting flange screws.
  11. Carefully pull the blower motor forward in order to avoid distorting the fan and pry back on the right side of the instrument panel to as necessary to remove the blower motor.
To Install:
  1. Guide the blower motor assembly into position. Avoid catching the blower fan on any protruding parts.
  2. Install the blower motor mounting screws.
  3. Install the blower motor cooling tube and blower motor cover.
  4. Install the bolt in the right lower instrument panel support.
  5. Connect the electrical connectors, as necessary.
  6. Install the mounting bracket and the powertrain control module (PCM) if removed.
  7. Connect the electrical connectors to the PCM, as necessary.
  8. Install the right kick panel trim.
  9. Install the screw into the front door sill plate.
  10. Install the glove box in the instrument panel.
  11. Connect the negative battery cable.
  12. Check the operation of the blower motor.
How do I take the dash apart to change the blower switch on a 2001 Mustang? I can not find a diagram or maunual that shows how to do this, can you recomend?
  2. Remove the control panel assembly from the instrument panel.
    A special tool, such as the one shown, is necessary to disengage the temperature control cable from the back of the control panel
    Temperature control cable component identification
  3. Carefully lift the lock tab to detach the temperature cable from the control door shaft.
  4. Note the cable routing, then remove the cable from the vehicle.
To install:
  1. Route the cable behind the instrument panel, then engage the alignment pins and attach the temperature cable to the control door shaft until the lock tab snaps into the groove on the shaft.
  2. If necessary, install the instrument panel.
  3. Engage the cable end with the cable actuator on the control assembly. Install the control assembly in the instrument panel.
  4. Connect the negative battery cable and check the system for proper operation.
  2. Remove the snap-in trim molding in the center console to expose the four control assembly attaching screws. Remove the four screws attaching the control assembly to the instrument panel.
  3. Roll the control panel out of the opening in the console.
    Exploded view of the heater control panel mounting
    Click to Enlarge
  4. Detach the temperature control cable from the control panel by using Ford Temperature Cable Disconnect tool T94P-18532-A, or equivalent, to release the side locking tube, and a small flat-bladed prytool to release the top locking tab. Pull the temperature cable away from the heater control.
  5. Remove the two mounting nuts, then separate the vacuum hose and wiring harness connectors from the back of the damper door switch.
  6. Detach the wiring harness connectors from the back of the blower motor switch and the light bulbs.
  7. Remove the control panel from the center console.
    To remove the control panel, first remove the trim cover and remove the panel mounting screws . . .
    . . . then disengage the locking tabs on the temperature control cable . . .
    . . . and detach the control cable. Detach all wiring harness connectors and remove the panel
To install:
  1. Position the temperature cable at the midpoint of its travel, directly between the H and C markings. Position the temperature control knob at the midpoint of its range, then connect the temperature cable to the geared arm on the blower motor wheel. Rotate the temperature control knob from maximum cold to maximum warm to verify proper range of motion.
    Prior to installing the temperature control cable, turn the control knob and the cable indicator to the mid-points of their ranges
    Click to Enlarge
  2. Install the electrical connector at the following locations: blower switch, control assembly illumination bulbs and damper door switch.
  3. Install the vacuum harness connector for the function selector knob and tighten the mounting nuts until snug.
  4. Roll the control assembly into position against the instrument panel and install the four attaching screws until snug.
  5. Snap the console trim molding into position, connect the negative battery cable and check the system for proper operation
1helpful
How to put in a headlight on a 2003 Chevy Trailblazer
Please follow the stepwise solution carefully.
1.Open the hood and disconnect the truck's negative battery cable.
2.
Remove the grille. Unbolt and remove the plastic panel over the radiator, then use a flat screwdriver to release the clips securing the grille at the bottom to the headlight panel and lift the grill off.
3.
Pull up the retaining tabs for the headlight housing, which are on opposite ends, and carefully pull the housing out. Remove the park/turn signal bulb socket from the housing by detaching the holders and electrical connectors and disconnect the side marker socket.
4.
Take off the circular access cover from the rear of the headlight housing. Twist the bulb in a counterclockwise direction, withdraw the bulb with its electrical connector from the housing and disconnect the electrical connector.
5.
Hold the new bulb by the holder--do not touch the glass--as you connect the electrical connector. Place the bulb in the housing and twist it clockwise to lock it in place. Close the access cover.
6.
Install the headlight housing into the panel, connecting the electrical connectors, signal bulb socket and side marker socket. Push the retaining tabs in place.
7.Reinstall the grille and plastic radiator panel and reconnect the negative battery cable.
Problem solved.
Take care.
Need to remove dashboard 1992 ford aerostar
Check this procedure...
  2. Detach the wiring connector from the instrument panel, located in the engine compartment, by loosening the bolt and separating the connector halves.
  3. Remove the left and right windshield inside mouldings.
  4. Remove the defroster grille.
  5. Remove the glove compartment door finish panel.
  6. Remove the instrument panel steering column cover.
  7. Remove the four bolts attaching the steering column lower reinforcement. Remove the reinforcement.
  8. Remove the right and left cowl side panels.
  9. Remove the two nuts retaining the hood latch control handle and cable assembly to the left cowl side. Remove the control handle and cable assembly, then reinstall the nuts to hold the bracket and relay in place.
  10. Detach the wiring on the left cowl side panel and, if equipped, the vacuum hose harness connector. The number and location of the connectors may vary depending on optional equipment.
  11. Detach the brake light switch wiring connector. Detach the clutch pedal position switch on manual transmission equipped vehicles.
  12. Remove the steering column-to-extension shaft pinch bolt. Compress the extension shaft toward the engine, then separate from the column U-joint.
  13. Detach the transmission control selector indicator from the steering column.
  14. Disconnect the wiring from the windshield wiper intermittent control module and, if equipped, the wiring from the low oil level relay. Both are located to the right of the steering column.
  15. Disconnect the radio antenna lead-in cable at the right cowl side panel.
  16. Disconnect the heater temperature cable. If equipped, detach the vacuum hose harness connector.
  17. Remove the five screws attaching the top of the instrument panel to the cowl side top panel.
  18. Remove the one nut attaching the lower right side of the instrument panel to the cowl side panel.
  19. Remove the two rearward nuts, then loosen the two forward nuts located to the right of the steering column, attaching the instrument panel to the center mounting bracket.
The following removal steps require the help of an assistant.
  1. Support the instrument panel. Remove the three bolts and one nut attaching the instrument panel to the left cowl side panel.
  2. Carefully pull the instrument panel rearward, then disconnect any remaining wires or other components.
  3. Carefully remove the instrument panel through the left front door.
  4. If replacing the instrument panel, transfer all the components to the replacement instrument panel.
continue...
2helpful
I HAVE A VIZIO 42' LCD TV WITH A 8' BLACK BAR RUNNING VERTICALY THROUGH THE SCREEN. COULD IT BE THE CONTROLER BOARD
You panel has a TCON (timing control) board which feeds the panel connector (1 or 2) inside the LCD panel, the picture information is then broken down inside the panel assembly via a connection board. You have 2 options: Replace the panel or toss out the TV. If you are going to toss out the TV, you may as well make a project out of it and attempt to fix it... what's the worst that can happen? You break it? It's already broken. So here's what I would do. Take the TV apart (photograph as you go if you are worried that you will forget what goes where). Remove the LCD panel and place it in a clean area. I would clear the kitchen table, cover the table with a soft blanket and then place a bed sheet on top of that to keep the dust and fuzzies to a minimum. Place the LCD on your work area and patiently and carefully take it apart. When you get to the connector board inside the panel, disconnect the panel connection directly above the black bar (should be a hinge style connector, a tab will flip upward to release the ribbon cable) and then reinstall the connector. You need to be careful here, these cables can tear if you get too forceful with them. After you reinstall the cable, go ahead and reassemble the panel and then the TV. If this doesn't fix it, you are back to option 1... replace the panel or the entire TV. Option 1 is more often the TV as the panel cost is close to or more than the TV. Here's an illustration I made for you to give you an idea of what the connection board is doing:
Then signal comes in on the red connector from the TCON then goes out to the panel on the yellow connectors. This is just an illustration, your TV may be a bit different, but the principle is the same. I hope this was helpful, best wishes.
1helpful
Dashboard lights burning out, down to 1 illuminating tach, speedo, gas gauge. How complicated to replace?
one hour job. find bulb part number in bulb chart in owner manual.
go here for villager help.
http://groups.yahoo.com/group/villagerquest/
Section 13-01B: Instrument Cluster — Conventional 1996 Villager Workshop Manual
REMOVAL AND INSTALLATION Instrument Panel Finish Panel Removal
  1. Disconnect the battery ground cable (14301).
  1. Block the wheels (1007) to prevent the vehicle from moving.
  1. Turn the ignition switch (11572) to the OFF position.
  1. Shift the transmission range (TR) selector to MANUAL LOW (1).
  1. Tilt the steering wheel (3600) to the lowest position, if equipped with a tilt wheel.
  1. Remove the two instrument panel finish panel screws.
  1. Remove the instrument panel finish panel (044D70) enough to access the switch electrical connectors.
  1. Disconnect the rear windshield wiper/washer switch electrical connector.
  1. Disconnect the heated back window and light switch electrical connector.
  1. Disconnect the emergency warning switch electrical connector.
  1. Disconnect the SECURITY indicator light electrical connector.
  1. Disconnect the speed control on/off (CRUISE CONT. ON/OFF) switch electrical connector.
  1. Disconnect the headlamp switch electrical connector.
  1. Disconnect the autolamp/light switch rheostat resistor electrical connector.
  1. Remove the instrument panel finish panel with the switches attached.
Instrument Cluster
Removal
  1. Remove the four instrument cluster screws.
  2. Remove the transmission range indicator (7A110) from the instrument cluster (10849).
3helpful
Replace airbag on `92 honda accord
When an SRS cable reel assembly is removed and set aside during vehicle repairs, the cable reel may rotate inside the assembly so it is no longer centered. If the assembly is reinstalled with the reel off-center, the cable can break when the steering wheel is turned to full lock. The cable reel holding fixture locks the reel while the assembly is off the vehicle, keeping it centered for reinstallation.
CABLE REEL REMOVAL PROCEDURE
1. Follow the procedure in the appropriate service manual for disconnecting the battery, and removing the dashboard panels, steering column covers, airbag, and steering wheel.
^ Always install short connectors on the connectors for the driver's and passenger's (if so equipped) airbags.
^ Make sure the front wheels are pointed straight ahead before removing the steering wheel.
2. Verify that the cable reel is centered; the yellow gear tooth is lined up with the alignment mark on the cover. Install the cable reel holding fixture in the cable reel assembly as shown. Use a TORX T-10 wrench.
3. Disconnect the 6-P connector, then remove the cable reel assembly.
CABLE REEL INSTALLATION PROCEDURE
1. Verify that the front wheels are still pointed straight ahead.
2. Reinstall the cable reel assembly, and reconnect the 6-P connector.
3. Remove the cable reel holding fixture.
4. Follow the service manual procedure for reinstallation of the steering wheel, airbag, steering column covers, and dashboard covers.
5. Verify SRS operation as described in the service manual. Road test the vehicle.
^ If the steering wheel spoke angle is not correct, change it by adjusting the tie rod ends. Do not remove and reposition the steering wheel.
PARTS INFORMATION
Cable reel holding fixture:
For 1992-95 Civic and Ohio-produced 1992-95 Accord
P/N 77900-SPO-999, H/C 4733564
For 1991 Accord Wagon, 1992-95
Prelude, 1995 Odyssey and Japan-produced
1992-95 Accord
P/N 77900-SM5-999, H/C 4733572
WARRANTY CLAIM INFORMATION
Use the Flat Rate Manual information for the repair being performed.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
