This product is very unreliable and if you purchased it 2nd hand you know why the owner wanted it gone. The base of the machine also breaks after regular use.
Unfortunately they are also expensive to repair and I would not be throwing any money at it but try to sell it off as a repairable item.
An inexpensive exercise bike is probably a better choice than a treadmill which generally are quite expensive for a quality product.
SOURCE: Wiring diagram need for an Smoothfitness EVO treadmill.
Solved this problem by contacting the Evo/Smooth directly. Great service.
SOURCE: how can fix my healthstream LS720T treadmill?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Testimonial: "awesome!!!! just briliant.........i just follow the procedure do a bit of adjustment then presto!!!problem solved !!!! thanks a lot !!!!!!!!!!!"
SOURCE: My Vision Fitness treadmill reads E6 when I turn
If
the machine is plugged into a working outlet, make sure the safety key
is in the keyhole on the console. If the safety key is not plugged into
the machine or if it is pulled out during operation, the treadmill will
not operate.
Finally, make sure the circuit breaker located on
the frame near the power cord is set to "Reset." The circuit breaker is
set to "Reset" if the top of the button is pushed in. When the breaker
is tripped, push it back to the "Reset" position and wait five minutes
before powering on the treadmill.
If the treadmill shuts
off during operation, check the power cord and circuit breaker as
described above. You can also try removing and reinserting the safety
key.
SOURCE: incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
