John the governor is probably sticking, check for dirt and debris, make sure spring/ linkages are still attached, after cleaning lubricate linkages with lubricant WD or similar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Throttle stuck wide open Governor issues
Understanding and Adjusting your Governor on small engine
How To Adjust Mechanical Governor On Small Engines
Briggs and Stratton 8HP Throttle and Governor Setup
