It sounds like you've pre-programmed a certain sound that is usually only triggered by multiple keys into one key. The most efficient way to return to the way that you're searching for might be to perform a factory reset on your device. But you should back up any data into a USB stick before you perform the reset as all data in the Casio device will be reset.
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
You will need to contact the Casio parts department and they can provide you with an electronic schematic for your CPS-80 digital piano. This document is not available to view on the Casio website
Casio Parts Department
Verify the power adapter is the exact one specified. If you run on batteries, replace them with name brand ones. Just because the display lights does NOT mean the electronics are happy with the power.
NORMALLY "fingered" mode means that you have to "finger" the chord, that is, play all the notes of the chord. It sounds like it IS working as designed.
Unfortunately your model of Casio only has midi in and not midi out. You will be able to use it as an external sound module but not to input notes into Fruity Loops. In other words midi out of your computer to midi in of the Casio with the proper settings will play your Fruity Loops sequences through the Casio.
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
