Hi mazhar , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi mazhar , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
I also cracked my Canon Powershot A630 lcd screen by dropping the camera. I saw a suggestion to buy a new replacement lens and either have it professionally replaced or try it myself. I ended up doing the replacement myself following instructions I found online. Now it works. Total cost US $63.
I would not recommend trying the replacement yourself, however. There are a few very delicate plastic parts in there which I ended up damaging. Luckily the camera and lcd screen are working great now. But it is probably worth having a professional camera repair shop do the whole job or insert the screen you've purchased. Good luck!
Did you accidentally hit the lower left "Display" button on the back of your camera? It manually turns the screen on or off to save batteries. Turn the camera on and press it once to check.
