A flashing green light on a Swann 960H Pro Series security camera system can indicate a few different things, depending on the specific model and configuration of your system. Some possible causes of a flashing green light include:
The camera is in setup mode: When a camera is first powered on, it may flash a green light to indicate that it is in setup mode and ready to be configured.
The camera is in standby mode: When the camera is not actively recording, it may flash a green light to indicate that it is in standby mode and ready to start recording.
The camera is recording: Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is recording.
The camera is low on power: Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is low on power.
The camera is malfunctioning : Some models of the Swann 960H Pro Series security camera system have a green light that flashes when the camera is malfunctioning.
All smoke alarms that connect to your household electricity must be replaced every 10 years by code (NFPA 72). Chances are the device is indicating low battery, but it is time to replace it and all others of the same age. Check your local hardware store or call a licensed electrician to replace them.
Make sure that the DVR hard drive is not defective, if it is in working order go to schedule recording and select your recording based on motion, alarm or continous
At first set the recording lenght on your phone(example 5 min) and then start recording, after the recording length is completed it automatically saves your recording file
