Dryers Logo
Why wont my maytag centennial dryer wont stay on. . All I did was move it from room to room
Our Maytag centennial dryer has a major problem with lint getting all over the top of it and around it in laundry room
Check to see if lint filter is intact and also check the exaust duct hose to make sure it is intact and not leaking.
Bad motor is one possiblilty..
May 26, 2014 • Dryers
Maytag centennial dryer wont heat up
I was working on a dryer similar with a no heat problem and made a video you might be interested in:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My centennial dryer will only stay running if I hold the start button in
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
I have a Maytag Centennial gas dryer and the dryer will not turn off when the door is opened. I'm assuming this is due to a broken switch on the dryer door. How can I repair this?
door switch is correct you will need to unplug the dryer and open the cabinet open and replace switch, this website will assist you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
2helpful
Looking for diagram to put belt back on barrel in the maytag centennial. pulley has fallen to bottom and do not know where it goes back to. maytag centennial commercial dryer medc400
Copy and paste this Factory Service manual for the Centennial dryer.
It has all your answers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/79aaf530992e93a0852572c3006587ed/$FILE/8178629.pdf
Sep 06, 2010 • Dryers
2answers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
