Question about Invacare Health & Beauty
Key flashing red on Invacare acs wheelchair controller
  • Invacare Master
  • 1,345 Answers
Hi count the number of times it flashes and check youre owners manual for a fault code....try this site manual-Invacare www.invacare.com.au ...cheers
Posted on May 07, 2016
Anonymous
SOURCE:
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Pronto m91
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
Jul 08, 2014 | Invacare Supply Group Invacare Pronto M91...
How to recharge but I get a flashing red light on transformer in battery box. this is a Invacare Pronto M91 Electric Wheelchair
The red light on the transformer/Charger means the charger is bad. Sometimes it can also be battery harness wiring. Most often it is the charger that needs replaced.
Jun 22, 2014 | Invacare Supply Group Invacare Pronto M91...
Turn on key shows full charge.but within 30secs one green goes out and one red starts flashing invacare scotter
those lights go by voltage not amps the battery has charge the battery then remove it bring it to a auto parts store to have it tested
Mar 31, 2012 | Electric Mobility Invacare Pronto M41...
Acs typh. invacare electric wheelchair, red light showing hand controls locked, cannot unlock it. please help asap.
Press the power button on then press the horn button twice before ten seconds. this should unlock the joystick
Aug 14, 2010 | Invacare Pronto M51 Power Wheelchair
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
I have a invacare wheelchair pronto91 wont move 2 red lights flash 3 times
The three light flash indicates a short circuit between the left motor(as you are sitting in the chair)and the battery. Check all the wiring from the control box to the motor and make sure it is not damaged in any way. If it is okay, you have most likely fried the left side motor. A new motor-gearbox assembly for this chair runs in the neighborhood of $1,400.00, or you can take the motor off and take it in for a full rebuild for about $250 or so. Unplug the joystick and remove the seat and cowl. Jack up the left side with both motors in gear. Remove the center nut cover and take off the nut holding on the wheel taking care to retain the key that slides into the groove on the axle. Disconnect the wiring plug to the motor and remove the six bolts holding the motor to the frame. Separate the gearbox from the motor and take the motor to a rewind shop for repairs. Reinstall and it should be good to go.
Jan 03, 2010 | Invacare Supply Group Invacare Pronto M91...
Wheelchair problem
sounds like you might have locked joystick by mistake. Try pressing and holding down the on/off switch for 5 seconds.
Jun 14, 2009 | Invacare Supply Group Invacare Pronto M51...
Health & Beauty Logo
326 people viewed this question
Top Invacare Health & Beauty Experts
Rob Hill
Rob Hill
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
