Panasonic DMR-E55 DVD Recorder Logo
Ernesto Niles Posted on May 08, 2016
Turn on but dont reject
Took out one of the flexible tape it rejected how can I GET A NEW FLEXIBLE TAPE PART
5 Related Answers
robert van d
  • Posted on Aug 22, 2007
SOURCE: tape rack stayed open
I just experienced the same problem, but it took me 10 minutes to get it working again. When you look inside the tape rack, you see on the left side in the middle a little mechanical arm which you can press down for about 1cm when you release it again the rack opens completely Good luck Robert
Anonymous
  • 221 Answers
  • Posted on Sep 25, 2007
SOURCE: Panasonic AG-1980
most likely problem is a dirty or defective mode switch. this switch tells the internal computer what position the mechanism is in. if the switch is bad, the computer is "confused."
Anonymous
  • 4402 Answers
  • Posted on Dec 03, 2007
SOURCE: the camera rejects the tape, I canĀ“t get it in
Have you tried a different tape? are you going from outside to inside? might have condensation just let it sit for an hour.
David Low
  • 458 Answers
  • Posted on Aug 14, 2009
SOURCE: my VHS is not reading the tape
Take the top cover off & have a look on the right hand side of the deck when your tape is playing. Is the tape riding up when it meets the pinch roller ( a small black roller on the right side)? If so the roller is either dirty or worn & would need to be replaced, this will cause your tape to crinckle & damage the tape.
Anonymous
  • 16 Answers
  • Posted on Jan 05, 2010
SOURCE: Was looking to buy one, and before the seller
the tape deck has jumped timing and can cost 40 to 100 dollars depending on how quick it takes the tech
Rejects tape seconds after inserted. Have tried new and used tapes.
ok sull! you have defective belt drive, or your sensors are not working, clean your sensors under the cassete tape! and maybe defective timing gear!
Why does my tape reject just after inserting?
Generally some part of the mechanism has become damaged and so can't perform correctly. It can't even unload correctly. You have to look around for plastic parts that have either got broken or out of place. New parts then need to be ordered. You will also need a service manual to set up the mechanism correctly once it is fixed. VCR's are rarely set up in the eject mode!
2helpful
When I put inthe video into the video it at once reject it..
Reset if exists will not help---if machine instantly ejects the tape there is a problem in the mechanism.
A look inside with top cover removed will likely reveal tape is not going all the way down or not being pulled out of the cassette and the machine will sense this and kick the tape back out.
Most common cause for this a bad loading belt or something in the mechanism that is not moving.
It can be a do it your self fix if a belt etc.
Cassette jammed, system cutting out.
Take cover off and turn the loading motor until it come out.
Sony Handycam DCR-HC38 is rejecting the head cleaning tape
camera has bad tape loader and or bad tape sensors. sounds drastic but bang it a few times with the palm of your hand. if this doesnt work contact sony service center
6helpful
Canon mv 800, camera does not accept tape cassette.
ok what you do is take the batery pack out and hit the camera there/
if it dont work try again
3helpful
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Camera dead
there is a fuse blown it happens alot just make sure when you send it in that the shop is a certified jvc or a jvc only repair shop some places fix alot of different brands of cameras and sometimes you might not get it fixed right away because of the workload or not at all
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
