Hi, can someone out there please help me with a very old Hoover Logic 1100 washer/dryer model A8536. It started leaking and after taking the back cover off, I found that it is spewing dirty water out of the 2 holes in the outer drum just below where the drum pulley is attached. Also, there is what looks like a water trap, (clear plastic "small bottle") which is attached at the back of the outer drum that has a exit tube which attaches to a pressure switch via a plastic tube. It used to fill with water but has stopped doing this, seems to be blocked. I have tried removing the 2 clamps and short black rubber pipe that attaches the "water trap" to the back of the drum, but it will not come loose. Firstly, does anyone have any idea why it is leaking out of these 2 holes and what the purpose of these holes are? Secondly, what is this "Water Trap" for and how do I remove it to clean it out? Thirdly, does the "blocked water trap" have anything to do with the leak from the 2 holes as explained above. I would really appreciated any suggestions. Thanks! Frank
SOURCE: Hotpoint WD64, leaking water from soap drawer
your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
SOURCE: musty odor
Unfortunately, this is a common problem with front load style washers. Now...if you pull the rubber boot back where it meets the wash tub there should be several small holes that allow any residual water to drain back into the wash tub. If these holes become clogged with lint and/or debris water will accumulate and mildew. The best advice I can give you when it comes to this type of washer is to become diligent about ensuring nothing gets caught in the the seam of the rubber boot. Routinely inspect this area after each wash for loose items like socks and underwear. In addition, clean this area periodically. What I often recommemd to people is to wait until you get ready to do a load of towels and wash cloths. Clean this area with a dirty towel or wash rag and throw it into the wash to be cleaned. This way you don't have to worry about having any old rags lying around. If you are not in the habit of using hot water settings you should also run a cleaning cycle about once a week on the hottest setting available. Pour a small amount of bleach into the soap dispenser and run the unit with nothing in it. This will help in killing any bacteria. Some of the newer models have now been equipped with a "Clean" cycle just for this purpose. Due to the design of these washers they become breeding grounds for mildew because the wash tubs are dark and if you leave the door closed when not in use it seals out any air that could allow the tub to dry out. When you are not using the washer leave the door slightly ajar to allow the tub to air out. I hope you find this information is helpful. Post back with comments and let me know if this works for you, or if I need to give you better advice.
SOURCE: Suds leaking from back of washer near top
I have the same problem now and again on my front loading LG. I
noticed that it is coming out of a vent on the tub right where you
metioned that is part of the design. Either there is too much
detergent or the drain is restricted. When there are lots of suds
they have to go somewhere. It's either out the drain or out the
vent.
But seriously, take it out back and shoot it at you're earliest
convenience and steer clear of LG appliances in the future. Good
luck!
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
