Question about Coby KyROS MID10244G 101Inch Touchscreen Tablet Computer
Where can i get a copy of the operating system and software. everything got erased from my tablet
When i turn it on all i get is a white screen
  • 1,387 Answers
You may be prematurely concluding what the problem is if thinking everything is erased is based on the fact you get only a white screen. First contact the manufacturer's tech support or the seller of the tablet to help with diagnosis and resolution.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on May 11, 2016
6ya staff
SOURCE:
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
Jan 04, 2016 | Tablets & eReaders
Why do i have an FBI warning on my tablet?
You have a virus! I would wipe everything back to factory settings by reinstalling operating system!
Jan 10, 2015 | Polaroid Tablet Computer PMID701
My tablet wont pass the prestige elite screen, what do I do?
Try this, hold down the power button, and the
Volume down buttons at the same time. Keep holding
Until you see a 3d android, lying on it's side.
Then use the volume down button, scroll down to either,
system reboot. Or factory reset ( if you have an SD card in, take it out first)
The reboot will just reboot your tablet, and it should
Turn on and fix the problem.
the factory reset, will erase everything in the system.
If it ran alight before, and you had stuff saved to the
Tablet, it will erase it also. I'm sorry but it can't be saved.
so make sure your SD card is not in.it will erase it too.
The factory reset will restore the tablets settings, and reboot. But only do this as a last resort. Hope this helps
Aug 23, 2014 | Tablets & eReaders
Xelio 4gb wont turn on
Had same problem, turned out to be fault in firmware operating system, replacement tablet.
Mar 22, 2014 | Tablets & eReaders
How do i reset my asus tablet
Step 1. In the device,select settings on the application list >select back up and reset >factory data reset >reset tablet >erase everything. step 2 . The system will erase all user data and reboot automatically. Please note all data will be erased from tablet!!! 12_22_2013_7_37_26_am.png
Dec 17, 2013 | Tablets & eReaders
Archos 101 wont turn on
System recovery
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
Jan 24, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
I reformat my archos 101 tablet, now all the files are gone, when I turn it on all I see is Archos A101IT Recovery, can you please help. Thanks.
20.3.1. To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- To move from one Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. Recovery mode options No: Cancels the system recovery.
Repair System
Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
HOPE IT HELPS AND GOD BLESS!!!
Jun 27, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
I installed xp and my pen dont work
I would reinstall it as per the instructions from HP. as there may be drivers missing.
Copy attached.
Software Pre-installed Software
HP Mobile Printing for Notebooks
HP Help and Support (XP Only)
Safety and Comfort Guide
Adobe Acrobat® Reader v. 5.10
Microsoft Reader v. 2.5
Zinio Reader v.1.4
Sun Java 1.4
Windows Media Player 9 for XP
HP Tablet PC Tour
*Intervideo WinDVD Playback Software v. 4* (Pre-loaded) Recommended software/services Availability of recommended software applications or services may vary by region and may require additional purchase and/or subscription
FranklinCovey PlanPlus (30 day trial period)
MindJet MindManager 2002 for Tablet PC (21 day trial period)
Alias SketchBook Pro (15 day trial period)
Zinio (see Digital Magazine icon on Tablet PC desktop for more information)
ScanSoft Omniform Filler 5.1 and Dragon Naturally Speaking Standard Edition 7.1 (available as a special configuration) Additional software available through the web HP Client Manager Software
HP ProtectTools Smart Card Security Manager
QuickLook for the HP Tablet PC TC1100 series *NOTE: Software is loaded on the hard drive and must be installed by running the Software Setup utility. System Recovery Each unit is shipped with a recovery CD kit containing Operating System Recovery and Driver/Application Recovery CDs. These CDs allow users to either recover or repair the tablet's operating system and select drivers without losing personal data. The Operating System CD also provides the option of reinstalling the operating system software provided with the tablet.
Feb 27, 2011 | Compaq tc1100 Tablet PC
Coby KyROS MID10244G 101Inch Touchscreen Tablet Computer Logo
62 people viewed this question
Top Coby Tablets & eReaders Experts
 Mike M
Mike M
Marvin
Marvin
Lawrence Oravetz
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
