SOURCE: toshiba estudio 282 has error code cc90--how to
good day cc90 is the top tray of your finisher (sorter) is causing the fault it is usually caused by there was something heavy put on the top tray or somebody bumped the tray. the bushes on the tray that is lifted by the motor are faulty and need to be replaced by a qualified technician if you need to use the machine please switch off the machine and unplug the finisher (sorter) switch on and the machine will work and obviously not sort or staple i hope that this quick fix will help you out until a technician can repar your finisher (the plug for the finisher is at the back of the machine above the power inlet behind a small cover)
