Fitbit Surge Large-Size Fitness Watch with Heart Rate Monitor Logo
E
Elsa Balderama Posted on May 12, 2016
My fitbit is 1 hour and 5 minutes faster than my orginal time.It reads 11:00pm when it should be 9:56?How do I change it to the right time?
My Alta fitbit has slowly lost time and now is 5 minutes behind correct time. How do I change it?
1. Change the battery.
Or
2."Help article: How do I change the time on my Fitbit device?" https://help.fitbit.com/articles/en_US/Help_article/1176
5helpful
How to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
NEED TO CHANGE TIME ON PHONE DUE TO DAYLIGHT SAVINGS PHONE IS T7316E
5.- Press softkey "CHANGE"
7.- Select AM or PM
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
15.- Press softkey "CHANGE"
16.- Enter month
18.- Press softkey "CHANGE"
19.- Enter day
2helpful
Cannot change time on the nortel ICS phone
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
3helpful
How do i change the time
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
2helpful
How to change time /
1.- To enter programming2.gif mode press "FEATURE" and "* * 2 6 6 3 4 4"
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___" 18.- Press softkey "CHANGE"
19.- Enter day
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
3helpful
4answers
How to change the time on screen
generic for all phones... the standard way to change the time and show it on screen is simply going to the settings and look for time settings... in here, you can actually change the time, the date , and the year and you can also change the time format form 12 hour to 24 hour.
Top Fitbit Exercise & Fitness Experts
SmartAviator
SmartAviator
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
