I bought ink. put it in properly. than the error came up.
SOURCE: says:ink system failed,unable to copy,fax,print
It means you are out of ink and on newer printers, it can be only one color that will cause ink failure.Check your ink levels and replace the color that is empty.
SOURCE: error oxc18a0106
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide to purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: cannot print
Try the following steps to remove HP Printer Error Code 0xc18a0001 :
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
SOURCE: what does error oxc18a0106 mean?? I
error detecting ink volume and will need to be cleared by resetting your printer. here are the two ways to reset it.
Reset to default setting
1. While your printer is on, unplug to
power cable from the printer.
2. Press and hold the "OK" and
"HELP" buttons while you plug the power cable at the back of the
printer.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ",
press "#" key and then release both keys."Enter Special Key Combo"
will be displayed.
3. Press "1", "2" and "3" to display Support.
4 Press
">" right arrow button and release when System Config Menu
appear, then click OK
5. Press arrow key to display Hardware Failure
Status, click OK.
6. When Hardware Failure Status:Clear appeared,
press "OK" to clear.
7. Press "OK" again to display "Hardware Failure
Status Cleared. Press Cancel To Continue".
8. Press "CANCEL" as many
times to display "Welcome To Photosmart Express" or "Ink System
Failure".
9. The last part is to turn off the printer and unplug at the
back, wait for 30 sec, then plug and turn on the printer, if asked,
press "OK" to continue and allow the "One Time Ink Initialization" to
procede..After this try to print.
Don't forget to rate this answer.
Thank you for using Fixya.
SOURCE: what does Oxc18a0106 mean - ink system has failed,
My C6180 had the same problem - eventually (within about 1 month for me) the printer would power on and off every few seconds. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures my printer was having. A similar fix may apply to other HP printers .
