Hi Tradeboyle,
Please search 'Sony Bravia KDL-40S4100 40 in five blinks' on google and you will get several videos containing the solution of your problem.
Good luck.
Alphrhttps://www.alphr.com > ... > Devices > Android
Aug 21, 2023 - A red light blinks four times instead. This occurrence is Sony's self-diagnosis option, indicating possible system malfunctions. The error can ..
You did not list the model number, by SONY general error code, 5-blinks toward to a defective T-CON board, a defective back lights invert board, or a defective display panel.
put jumper in between pin no 23 & 28 now your power supply is on but still no voltage at led out put error 6 code is particular for led out put not for t con so please replace power board complete
6 times power/ standby light blink error shows problem of back light inverter board in your Sony KDL-37M4000 tv as per mentioned in related service manual. Check back light inverter board to fix the issue. Thanks.
8 blinks in KLV-32S400A shows Audio Error Check audio voltage supply from power supply board, if OK, replace GP Board (main board) and if audio volts are not available, check/ replace power supply board.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
