How can I configure the scanner to a straight line instead of the box
SOURCE: NOT SCANNING CORRECTLY
I'm guessing you are using the USB version and the power that comes from the comuter via the USB cable.
It is quite likely that the problem you are having is due to power sag. .500ma is the limit from P.C. s
Do you have a 15 foot cord on there? If so try a 6 foot cord. Sagging still occurs with a 6 foot cable ...but only half as much. If the problem goes away you are on the right track.
I have a cable (I should say Motorola has a cable) with a separate power supply that should fix the problem.
SOURCE: Hand held scanner LS2208
At the Symbol web site they have some instuctions for programming a 'Tab' at each scan.
Follow this link....
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11124&sliceId=SAL_Public&dialogID=58352294&stateId=0%200%209199403
SOURCE: Can the Symbol LS4804-I400A scanner scan a QR code
No, this is a Laser Scanner. The laser beam can scan the barcode only in 1 direction (1D Barcodes). For QR Barcode (2D) you would need an Imager (Digital Scanner).
SOURCE: Symbol Model LS 9208, Bar
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
