Try to buy a new key. may the old once magnetic property may degraded.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Check connection of battery terminals to it's related cables. Try using one of the jumper cables to connect negative of battery to chassis.if still fail, try connecting to engine block. If fail, try recharging/replacing battery. Lights may stay bright but battery may mot have enough amperage to turn starter motor.
If your starter stays engaged after the vehicle starts with the remote starter then, the vehicle's starter wire is receiving 12 volts, most likely from the remote starter's ignition or accessory wires. Check the connections to the vehicle's wiring: the battery wire is constant 12 volts, regardless of key position. The accessory wire(s) is 12 volts with the key at accessory and on/run (position 1 & 2), the ignition wire(s) is 12 volts with the key at on/run and start (position 2&3), and the starter wire(s) is 12 volts with the key in the start position (position 3) ONLY. Make sure that the remote starter wires are connected to vehicle's wires as directed by the Bulldog instructions.
turn off headset
then press and hold on button untill the light stays on
not blicks i mean stays on on
then run your other bluetooth discovery
on your laptop
