Question about Bulova Watch
F645390 case number - Bulova Watch
How to replace the battery of a emporio armani ar0106
Do you have a photo of the watch case back? It's either going to unscrew in which case you may need a special took, or it might be a snap-back case in which case it can be pried off.
With the case back off, its best to use a magnifying glass or eye loupe to look closely and determine how the battery is held in place. It's usually not to difficult to discern how to remove it (if you send me the movement number I can guide more specifically. It's important to replace it with the same battery and it will be numbered for identification.
Dec 06, 2014 | Watches
Please tell me where the serial and model numbers arre on a Bulova marine Star 100m. men's copycay513@gmail.com
Most of the time you can find the serial and or model number on the first link that is attached to the case of the watch on the back. Often there is a serial number on the back of the case itself. If not in any of these locations you may have to open the case and look on the inside of the case. Be careful with opening case, if you're not comfortable opening the case yourself take it to a reputable jeweler.
If there are no serials on the watch it is probably a knockoff or replica.
Hope this helps.
Feb 27, 2011 | Bulova Marine Star 96G30 Wrist Watch
Does the tag heuer wk1113 wrist watch have a serial number on the back case ?
Yes. Its always under the Model Number. Some model numbers were etched, instead of stamped or engaved, on the case and over time may be worn off but on a newer watch it should be visible.
May 10, 2010 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
What do the number on the back of the Geneve Diamond ladies watch mean.
There may be three number on the back of a watch.
1) The case number.
2) the movement number.
3) the serial number for the case +watch assembly.
Apr 29, 2010 | Geneve 14K Diamond Cut Gold Face Watch...
On a rolex watch, does it have to have the serial
Numbers on case back are inside. Number on case is outside, located between lugs. You need to remove bracelet to see it. Rate me, plz.
Apr 26, 2010 | Rolex Daytona 116520 Wrist Watch
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
Mar 05, 2010 | Accutron Swiss Watch by Bulova 26B44
Does two watches have the same case number??
If you have two sets of numbers that are the same, then I would expect a third number (the serial number) to be present on both watches also.
Feb 02, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Can;t open back of watchto find date it was made do i need special tool or some thing else can be used
You definitely need special Rolex case back opener. Without it your watch will be locked forever. Rolex cases are so tight, that even when special opener is used, you will need quite strong arms to open it. Rolex case openers sometimes sells on ebay, but they are never cheap.
Jan 07, 2010 | Rolex Daytona 116520 Wrist Watch
I was wondering where to find the seiral number of my watch or how to identify what model number it is
The model sometimes is on the case back or inside the case back and the serial number inside on the movement. Therefore you would have to remove the case back. Be careful if you do this so you do not damage the case. Maybe better to have a shop do this for you.
Nov 20, 2009 | Bulova Millennia With Vibra-Alarm 98A48...
Numbers on the back of my watch don't match the style number
Style number is different from back case number. Back case number is for reproduction number only while the style number is a serial number of which honored in a warranty .I know this because im a Rolex technician before in saudi arabia.
Hope it may helps you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jan 08, 2009 | Movado 0604869 Watch for Women
Bulova Watch Logo
97 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Anthony Ward
Anthony Ward
Chan Sun
Are you a Bulova Watch Expert? Answer questions, earn points and help others
