Question about Daewoo Washing Machines
What is Error HI?
My washer is giving HI error whenever I try to start it. Plz help me to resolve it Thanks
    New Friend:
you didn't mention the model, but on the washer/dryer combo units, the H1 means the following:
Dryer temperature sensor error detected A fault has been detected with the dryer temperature sensor on washer dryer models.
  • Check connections to dryer sensor
  • Check temperature sensor
Posted on May 16, 2016
6ya staff
SOURCE:
What is the meaning of error HI?
Pull out the plug wait a minute. Plug back in.
May 15, 2016 | Washing Machines
What does it mean when the machine gives an oL sign when starting the wash cycle?is it a quick fix and how much will it cost? It is a top load whirlpool cabrio washer.
Hi
Thanks for using FixYa. Error oL means overloaded and it flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. To clear this error you’ll have to open the door lid to clear display, remove excess laundry, then restart the cycle. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have an error code oe displaying on my washer and washer will not spin , can you tell me where to start to fix the problem? thanks dwayne
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | LG WM2277H Front Load Washer
My washer will not start it says" F-01" and constantly blinks when I try to press start. HELP!
Hi
Thanks for using FixYa. Error F01 in your whirlpool duet sport indicates EEPROM error which means that a communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred. This error also occurs when the pump driver fails to activate and/or one of the main relays is not working. To resolve this issue leave the unit unplugged for 5-10 minutes so that if this was caused due to power surge it is cleared. Also check the CCU (central control unit), if bad you’ll have to replace it.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Stops filling and gives F1 code
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Nd on washer
Hi Zandra,
Thanks for using FixYa. Error code ND means “No Drain issue”. To start with you’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Having the same problem with 2008 dodge grand caravan. Car is not starting most of the time and giving a error message stating bad key. Dont have a second to to try. Not sure what to do? Plz help
If you boot for a few seconds and shuts down and gives you bad key problem could be the immobilizer which has the function to recognize the key and connect the engine computer which can be resolved by reprogramming the key. Thanks
Mar 02, 2010 | 2008 Dodge Grand Caravan
How to resolve network problem from mobile
try this code if its not helping u out *#7370# default security code is 12345
a replacment of connexion circuit/chip on the borad shud be replaced.
-serious soledring skills
-hot air skills
-using metrix skill
plz do rate this post as good as u can
Oct 28, 2008 | Nokia 6681 Cellular Phone
Samsung sgh d900
hello sure i have the honor to help you .
try to give its the Samsung master codes here its :
*2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
*#0523# - CONTRAST
*#9998*523# - CONTRAST
*#8999*8378# - Service Menu
plz rate this post
this may help you and help others !!
by markknof
best regard
Aug 28, 2008 | Samsung SGH-D900 Cellular Phone
Washing Machines Logo
150 people viewed this question
Top Daewoo Washing Machines Experts
Marvin
Marvin
Paul Bade
Fahr Quad
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
