you didn't mention the model, but on the washer/dryer combo units, the H1 means the following:
Dryer temperature sensor error detected A fault has been detected with the dryer temperature sensor on washer dryer models.
Hi A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps--- 1. Unplug washer or disconnect power. 2. Check door switch/lock unit. 3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU). Hope this helps...Please post back if you need more information. Daniel
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Hi Thanks for using FixYa. From what I understand the error code ND means “No
Drain issue”. You’ll need to check for any restriction in pump assembly. It can
also be due to a restricted drain hose or loose wire at pump. If after cleaning
the drain hose the issue is not resolved then it means the pump has gone bad
and unfortunately needs to be replaced. Please do rate the solution if the issue is
resolved or post a comment for further assistance. Thanks Rylee
Thanks for using FixYa. Error F01 in your whirlpool duet sport indicates EEPROM error which means that a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. This error also occurs when the pump driver fails to activate and/or one of the main relays is not working. To resolve this issue leave the unit unplugged for 5-10 minutes so that if this was caused due to power surge it is cleared. Also check the CCU (central control unit), if bad you’ll have to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Hi Thanks for using FixYa. Error F01 in your whirlpool
solution if the issue is resolved or post a comment for further assistance. Thanks Rylee
Thanks for using FixYa. Error F4 in your range means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Hi, The meaning for ddo error means"Dispenser Drawer Open" .To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it. Thank you !!
Hi Chittu,
This error usually happens when there's problem reading and writing from the Flash memory card (CF).
Did you try to pull the memory card before the camera finished writing data?
Here's what you should do - try using another memory card. If it works, it means that the original one is damaged.
Let me know if this helped.
Please rank this post.
