Question about Fuji FinePix Cameras
My camera has a problem which I know why , because I plugged a flash cable in a DC then it went dead completely . pls I love and is this problem fixable ?
2 Suggested Answers
6ya staff
SOURCE:
robmcd27
Rob
  • 423 Answers
SOURCE: Put compact flash card in and camera went dead.
Take out the cf and see if your camera turns back on without it. If it does, then you have a bad card...replace it.
Rob
Posted on Mar 05, 2009
Cannot get the flash to work
The flash will not work in all modes
Make sure A (auto) is selected
The strange box you refer to may be the quality icon (a white box with a shaded box inside ?)
Try using a different flash mode instead of 'red-eye'
Make sure the battery is in good condition - try the mains adapter if you have one
May 13, 2016 | Gateway DC-T50 Digital Camera
Camera will power-up only when connected to DC
Have you checked the batteries to make sure they are still viable?
Oct 11, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Hi, I plugged my Creative Zen into the charger and then it just died. It is completely dead. It won't turn on. I even tried to turn it on using the reset button. I have only had it for a month. I am so sad...
Can you kindly let me know what was the ratings of the charger which you used your phone is made to be charged with 5V DC and 1.5Amps. In case you used a 12V DC adapter then most probably you could have just damaged the charging circuit. and your phone went to self secured mode. My suggestion at present is to remove the battery for a minimum of 15 minutes from the phone alongwith sim and then try to charge it with a proper adapter for a minimum of 8 hrs before trying to switch on the phone.
Thankyou for using fixya free utility.
Mar 19, 2011 | Creative Labs ZEN V Plus MP3 Player
Whilst in use went completly dead canot resart
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 02, 2009 | HP Pavilion dv6000z Notebook
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
Rob
Feb 26, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony DSC-H7 won't work!!!!!!!!!!!!
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Missing charger/power cable
if the power socket is a normal socket like a nokia phone charger you might be able to get a universal variable volt adaptor. i got one for my base station for my ipod as i lost the mains adaptor. bought it from Argos though im sure there are other stores that sell the same or similar.
Mar 19, 2008 | Optimus DS-5080 Digital Camera
Hello there
Try to flash 2 x MCU and then STOP, disconnect the phone from the cable, remove battery and then connect phone to cable and software then try to the the Cust/FS on its own.
If that does not work please write here the version of the flash files your using or the file names.
Jan 29, 2008 | Sony Ericsson K600i Cellular Phone
Cameras Logo
50 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
