I hear it fill at beginning. I hear water in there. But then it starts cycling and getting loud. I look and no water inside. I have checked the drain hose and there is a loop in it taped to the back of the tub. This is a front loader
Is this a front loader?
Testimonial: "yes, front load maytag, has steam clean feature, stainless tub housing. 2010 model"
Yes , front load maytag, has steam clean feature, stainless tub housing, 2010 model.
The tube seal is leaking or an electro valve is stuck open most likely. It may be time for a repair person, the Maytag man may be needed unless you have a big assortment of tools and the skill to take this washer apart, if you do let me know and I will try and find instructions on teardown and inspection.
You are lucky you got 6 years of service out of this type of washer, I stick with top loaders because they last 20 years or more.
As far as help goes if an expert knows what's wrong for sure they would've answered. At this point maybe a local technician is needed.
can I get some help?
