Question about Apple iPad (16 GB) WiFi Tablet PC
Facebook does not allow my newsfeeds to come in on ipad you see blurry in back ground and cant open my messages on facebook
    New Friend:
  • 135 Answers
  1. First of all, you must have messenger app to open your messages
  2. try closing the app, restarting your ipad & re-open the FB app again.
  3. Uninstall app & install a clean version again
  4. if above didn't work; you can use safari to open your FB account as if you are opening it from a desktop/laptop
Posted on May 19, 2016
  • Collins Oranga
    Collins Oranga May 19, 2016
    Are you on Wifi or cellular network connection?
  • Tamer El Guoshy May 19, 2016
    I think as it is mentioned that device is WiFi iPad in the category of question.
Anonymous
SOURCE:
Keyboard shortcuts
Messenger has 5 icons at the bottom of the screen. From left to right,
Recents, which is conversations you have had.
Calls, which is a list of people who have a device you can call,
Groups, which enables you to select a number of friends to message.
People, which is your Contacts directory.
Settings, which allows you to set up your phone number, and various options including Help.
Messenger is part of Facebook, so make not play ball with iPad settings.
Apr 03, 2016 | Tablets & eReaders
When I received this iPad from my daughter & loaded my Facebook it opens in her Facebook. She had every thing removed & reset before she gave it to me.
Get your daughter to go into her Facebook account.
Ask her to go into account settings. You will find an area that allows you to sign in it of ALL devices.
This should disconnect her Facebook account from your iPad.
Uninstall the Facebook app. Soft reset the device (power and home button) then reinstall the app when it comes back on.
Let me know if this helps.
Apr 28, 2015 | Apple iPad 32 GB 3G Tablet PC
Why won't Facebook open on my desk top but I can log in on Google
I'm confused - are you asking about a desktop (ie: PC) or iPad? Actually, in either case, you may need to check your security settings in Facebook using a device with which can login from - it could be you need to allow the iPad login in Facebook security under "Login Approvals" or you may need to use the "code generator". One tip is that you can opt to get approval codes via mobile phone text msg and then use that code on your iPad.
Dec 09, 2014 | Apple iPad 64 GB 3G Tablet PC
Why do I receive a pop up message "couldn't open messages" for one of my contacts on Facebook?
You might have been "unfriended" or ignored on the other person's side.
Sep 25, 2014 | Apple iPad 64 GB WiFi
How do I resend a message to the sender on facebook on ipad
Hi there maybe an easier way but this is how I do it tap on the message you want to resend it will open a box of options tap copy next Tap where you'd write a message... hold finger on there and paste comes up tap paste hope it's explained enough
Sep 11, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Facebook login problems
Have you tried to hard reset the device? To do this just press and hold the power and home button and the same time until you see the screen go black and the apple logo appear , now let go of both buttons, allow the tablet to start up. Try the facebook app again, does the problem persist? If the problem still persists, check to see how much space you have on the tablet, sometimes the limited amount of space on the device can prevent an app from functioning correctly. If you find there is not very much space remove several items, to create more storage space, then attempt to use the Facebook app again, does the problem still persist? If so, check the App Store to see if there is an update for the facebook app, if you find one under updates, install it, try to run the App again. I hope something here has helped you resolve your issue.
Sep 02, 2014 | Apple iPad 32 GB WiFi Tablet PC
How to remove iems from facebook timeline on ipad
It is not an issue with tablets but with facebook not allowing stuff to be deleted.
Jun 04, 2014 | Tablets & eReaders
IPad won't allow me to change Facebook users? We have two users and now can't switch between the two.
If you are having difficulties on the mobile site I would suggest downloading the free Facebook App for iPad from the iTunes store. You can touch the same 3 line symbol to open a side bar and Logout is at the bottom. https://itunes.apple.com/us/app/facebook/id284882215?mt=8
Unfortunately, if you are on the mobile site the only way to switch to the Desktop site is to open the left side bar.
If you are using the app, try deleting it, then reinstalling. You may also want to see if there is an update available which may fix it as well. If all else fails, use safari to try to use the mobile website.
Best of Luck!
Jul 10, 2013 | Apple iPad 2 Wifi 16GB
Apple iPad (16 GB) WiFi Tablet PC Logo
Top Apple Tablets & eReaders Experts
 Larry
Larry
john smith
gaucherre
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
